1991 3FE banjo fittings
Exeter California USA
Does anyone know the part number for the banjo fitting that goes from the gas tank to the fuel rail? I lost that one when I pulled the intake manifold off.
Any help would be greatly appreciated!
Ted Henderson
Is this what you’re looking?
That's the one for all the 1FZ-FE engines, but the 3FE has two types, and that is one of them (for the fuel filter). They all use (2) of 90430-12005 gasket (washer). You can also sub the double aluminum washers, if you want. The dealers have these in stock; they're used everywhere.
The cold start fuel pipe uses (2) of 90401-08004, which uses (2) of the gasket (washer) 90430-08011.
There are 6 banjo fittings between the fuel tank and the fuel rail on a 3FE. All banjo fittings are attached to a section of hose, so I don't understand what you're looking for and how you can loose a banjo fitting, unless you're looking for the hose assembly.
Please be more specific or go to partsouq.com and enter your VIN and find what you're looking for.
Ted Henderson
To be more specific, I'm looking for the fitting that goes to the fuel rail that sits on top of the injectors.
Thanks
Ted
I thought as much. See my post above.
BTW, I think you mean to say "banjo fitting". If you said that to me, I'd assume you meant the removable, drilled bolt, and not the fitting crimped onto the
hose.
Thanks
Ted
The rear most top port of the fuel rail is the fuel pressure damper (23207-74010) the thing with the white plastic cap with a set screw under the cap. That mounts with a banjo fitting. That banjo fitting is what feeds the fuel rail.
