I have my 2nd 80 series I've owned on the way to be delivered, this one with a 1HD-T and only 64k miles on the clock. I had no real experience or confidence to do anything besides oil changes or lift kits before I touched my last FZJ80. But after going through the Comprehensive Baseline thread, I've gotten comfortable and confident in wrenching myself instead of sending it to a shop.
As the first diesel I've ever touched, what kind of things should I be looking for besides the typical fluids, hoses, the soup etc. Asking more for the diesel specific(?) side of things to look for (aneroid pin, injectors, IP..). It seems like EGT is step #1 before all.
Also wondering as I search for more power when I start adding gear, what would be the proper order of installing parts if I ordered 1 by 1: gturbo, intercooler, injectors, IP? What order would cause the least bottleneck effect on the performance of the rig?
For my own reference of possible plans, but if it helps anyone else:
FLUIDS:
OIL: SAE 10W-40, 9.3L (API CF/4 or ACEA: A3/B4)
TRANS(Auto): ATF 6L (Dextron ll, lll, Type 4 (T-IV))
TRANSFER: SAE 75W-90, 1.4L (API GL-4 or 5)
FRONT AXLE:
W/ Lock: SAE 75W-90, 2.7L (APL GL-4 or 5)
W/O Lock: SAE 75W-90, 2.8L (APL GL-4 or 5)
REAR AXLE:
W/ Lock/Standard: SAE 75W-90, 3.25L (APL GL-4 or 5)
LSD: Hypoy LSD 90, 3.25L (LSD API GL5 or 6)
POWER STEERING: DEX ll/lll, 0.8L
COOLANT: Toyota or Aisin, 12L (RED or BLUE)
BRAKES: SAE J1703/4, 1.2L (DOT 3 or 4)
AIR CON REFRIGERANT:
W/O Rear: R12, 850 +/- 50 gms
W/ Rear: R12, 1300-1400 gms
FILTERS:
Oil Filter: 90915-30002/90915-03006 or 15600-41010
cruiserteq.com
Fuel Filter: 23303-64010
Air Filter: 17801-61030/17801-68030
Amazon product ASIN B004C63FMI
BELTS:
Fan/Alternator: 9091602452
TIMING BELT/WATER PUMP:
forum.ih8mud.com
Timing Belt: 13568-19065
Idler Pulley: 13505-17011
Spring Tensioner: 90507-27003
Camshaft Seal: 90311-32020
Aisin Waterpump: 16100-19235
MISC:
Timing Cover Gasket : 11328-17010
Valve Cover Gasket: 11213-17010
Glow Plug Assembly: 19850-64031
Thermostat: 90916-03089
toyotaparts.mcgeorgetoyota.com
Fan Clutch Assembly:
cruiserteq.com
FLUIDS:
FRONT AXLE:
REAR AXLE:
FILTERS:
Oil Filter - Fits 1HZ/1PZ/1KZ/1HD/2LTE Diesel Applications
Toyota Land Cruiser Oil Filters
BELTS:
Toyota Land Cruiser Belt, v(for fan & alternator) - 9091602452 | Wesley Chapel Toyota, Wesley Chapel FL
Belt, v(for fan & alternator). Toyota Land Cruiser. Genuine Toyota Part - 9091602452 (90916-02452, 9091602248, 9091602330). Ships from Wesley Chapel Toyota, Wesley Chapel FL
parts.wesleychapeltoyota.com
1hdt timing belt change
i know this has been documented elsewhere but every thread i've looked through is old and the pictures don't show up anymore so i thought i'd document my experience. as a word of caution im not the most knowledgable but am willing to learn so here goes. this is my first timing belt I've ever...
forum.ih8mud.com
MISC:
90916-03089 - Thermostat Ourisman Toyota Parts
Save Money On Your Thermostat (9091603089) For Your
Fan Clutch - Fits 7x/8x 1HDT/1HZ HDJ/HZJ Diesel Applications (FAN17010)
Toyota Land Cruiser Fan Clutch
