Looking for some guidance from the 3FE experts.
My ’88 FJ62 is currently throwing Code 21 (O2 sensor) and Code 28 (AFM).
History:
One thing that may be relevant: the exhaust has been modified by a previous owner. The factory dual-cat setup was changed and the truck now runs a single catalytic converter.
My questions:
At this point I’m trying to determine whether I’m dealing with:
Any input from those who have chased Codes 21 and 28 on a 3FE would be appreciated.
History:
- Originally had codes 14, 21, 22, and 28
- Found and cleaned a heavily corroded intake manifold ground strap
- After cleaning the ground, codes 14 and 22 disappeared
- Found exhaust leaks upstream of both O2 sensors and repaired them
- AFM was replaced during previous troubleshooting
- O2 sensors are installed and connected
- Engine runs reasonably well overall
My questions:
- Has anyone seen Code 21 persist on a 3FE with a single-cat setup?
- Could the modified exhaust configuration contribute to Code 28, or should I focus elsewhere?
- Are there specific AFM signal, E2 ground, or ECU tests you would recommend before I start throwing more parts at it?
- A remaining AFM/wiring issue
- An O2 sensor signal issue caused by the exhaust modification
- Or another shared sensor ground/reference problem
