1987 4runner rear brake
This is the problem with drum brakes. Mud gets in, but it won't come back out.
Swap to rear discs, problem solved.
This is what I'm using:
Toyota Disc Brake Brakets + Optional Kit - Sky's Off-road Design
Takes common Chevy Monte Carlo calipers, ~$20 each fully loaded. The toughest part is the brake rotors, you can buy them from Sky or buy Chevy truck rotors and have them machined out.
Overall an easy swap. Be advised you lose your e-brake capability. I solved this with a t-case e-brake setup.
