1985 toyota pickup 22r
I replace leakin fuel hose and than when i went go start my truck it wasnt get not fuel . I change the pump, the filter, the tank all new fuel hose and it still want start. i put fuel and the carb and blew air into the return line. nothing clogged. all those things and it still want start. any advice i dont know what else to do or is it something special that i have to do. it not a eletric fuel pump.
Maybe a stuck float??
Also could be a clogged line between the pump and the carb.
Like Jerod said, look through the window for fuel and if you have fuel, then it is a carb problem.
You might also check the fuel shut off solenoid, It could have been disconnected when you worked on the hose.
Dan
