1985 FJ 73 bolt pattern.
the wheels than can be use are, 40 series , 60/62 series, 70 series until 2000
3f engine is not a verry good engine, its ware very fast, if you play hard rpm with it , it wont last long. here in venezuela we bore the block to 1mm over, put downey 2f engine camshaft, a jxxp 4.2lts valve (a bit bigger) and install the inyection fron a fj80, but still a slow engine. probably easy to install a modern 1fz-fz its come with 230 hp
Thnx for the info. I was also thinking about installing the 24-valve, 4.5 L six-cylinder petrol engine, 1FZ-FE, but i think it requires so much work, and i am not sure it would fit perfictly.
Do u know someone who did the conversion?
well its fits but you need new engine chassis mount and tranny chassis mount. also if you found all the electric system it not that hard....
