1985 BJ61 Project Introduction (PICS)
New Zealand
I'm a very new member to the site but over the last 24 months i have been using the ideas and advice
from the members here so id like to thank you all. I'm 17 years old now i've got my hands on a Bj61 given to me by my father which was rough as guts and rusty but i stripped it down got all the bodywork restored. After getting it back to original form i've been slowly modifying the mighty Landcruiser.
The first thing i got was Old Man Emu 2.5 inch leafs out of Australia and some 15x8 -21 33x12.5 mudders.
It's a GX model with a 3B which is a very slow engine but still has lots of 4wding Torque.
Im currently searching for a 1HDft which are quite common in New Zealand.
I just wanted to introduce myself to the site and my on going project.
I hope I can help out here and there even though I'm young.
Thanks
George
220000km on the 3b
All arb suspension is from peter munro commercials in Christchurch, he gets all arb products out of Australia
You've done a very clean job so far!
The turboglide kit is a safe bet, and will be a great upgrade if the engine is in decent shape.
Welcome!
I guess it is 24v?
PTO Tip: upgrade the shear pin on the input shaft to the pto winch if you plan on getting yourself unstuck. Oem is scrap.
Also, it's nice to be able to turn the front portion of the wormshaft on the winch if you have to unload the tension on the winch while you are stuck, to change the shear pin.
I welded a 19mm nut to it, so it's quick to rotate enough to take the tension off the cable or just enough to swap the shear pin.
Welcome!
I guess it is 24v?
The 3b is great off road but on the highway it's pretty gutless so a turbo would be a good upgrade.
Yes it's 24v
Yeah I found that out a couple of weeks ago when I tried to get someone unstuck and pin broke into bits and is held together with a cut up Alan key for a quick fix. The 19mm bolt is a great idea, thanks
