1985 BJ 60 Trans in 1980 BJ40
I used the 60 crossmember in my 40, and again in my 45, cutting an inch or so off each end and moving the crossmember brackets on the 40 back till they lined up with it.
I did this with the FJ55 too. If I had the BJ40 type mount on the '55 I'd have used that which is what I did on my FJ45LV. I thought there was more than an inch that had to come off of each end of the '60 mount to fit the narrower frame of the '55.
OK, you seem pretty committed to putting a five speed into this rig in spite of the challenges... cool
Your best option is to sell it and by an 83 -84 BJ42
Next best, buy and 81-82 BJ42 and do the 5 speed swap. It already has brakes on the wheels, and under the trans crossmember, and a splitcase.
Both above options would get you a 3B diesel rather than your B and that would help get you into a power range where you'd actually use fifth.
Worst option, keep your BJ40 and put a five speed into it.
You can't use the t-case from the '85 BJ60 as has been said before. Find one from a '83 or '84 BJ60 as has been said before or an 1985 BJ70 (will have wrong flanges) as has been said before. Get the parking drum for a split case or swap out your rear axle housing for one from an '82-84 FJ40 or BJ42. ( I think this was said before) Probably even a BJ70 would work.
New info, your clutch is not quite the same as later versions but will likely work. If you get the one from the new tranny and its any good, use it. Be sure to get the throw out bearing retainer and clutch fork with the new tranny and if you get the bellhousing and clutch slave at the same time you'll be assured that you have what you need and can mix and match with your old stuff. Order a new clutch disc from the dealer. You'll end up with a spot for a tach sender as well and then you'll be able to see that you weren't actually revving that high in the first place.
See if you can get the t-case linkages from the donor t-case. I cant remember when Toyota went to the shifter-in-a-shifter for the transmission. Probably 85. It was basically a hollow shell over the shifter shaft with rubber poured in the middle. You won't have any luck bending it. You need a solid one from and earlier truck.
Would this way be easier?
Buy a 1985 BJ70 parts truck for 2 Grand and put the 3B motor and 5 trans case and trans in my BJ40 land cruiser?
However the BJ60 is 12 volt and my BJ40 is 24Volt?
Does that open up a whole new can of worms?
I did a 4sp to 5sp (h55f splitcase) conversion on a '81 bj42. Donor was an '85 60. Granted there are differences as pointed out in responses above, but here are some observations I made...
-bellhousing, clutch, crossmember, tranny mount were all interchangable.
-output shaft flange on the 5sp had to be swapped with the one from the 4sp.
-rear driveshaft had to be shortened 3" and the front lengthened 3" to accomodate the extra 3" length of the 5sp case. Cost me US$40 per shaft for a driveline specialist to do it.
-New holes had to made to accomodate the shifters, which also coming up further back. Fabricating a new piece altogether is actually not that expensive.
-Tranny sits only 1.5" away from the fuel tank, making it impossible to change the clutch or perform internal tranny service without pulling the engine. The tranny was in fact installed attached to the engine as one unit. Not that these engines are that difficult to remove, but it is more hassle.
-Make sure the donor is a diesel - I know of someone who tried to be 'inexpensive' and use a gasser donor. Input shafts are different in at least having a different number of splines.
I have been driving the conversion since April and the 5sp difference is amazing! Much higher top speed and better mileage!
Cheers and good luck...:beer:
the 24 to 12 stuff is no biggie.
Use the starter motor, alternator and glow system from the BJ40.
You can use the 70 rear axle and get a parking brake.
You'll have to meld the parking brake systems
You'll have to meld the throttle cables, they're not the same.
You'll have to customize the crossmember.
You'll still have to do driveshafts. (might get lucky and be able to use a BJ70 one)
You still have the shifter issues.
This one is for sale for $3000 if the other parts rig falls though. It's 24 Volt.
I should also add that it is very useful to obtain the exact date of manufacture from the vehicle - '85, as I found out, was a pivotal year for the h55f and there are multiple rebuild kit choices (mostly differences in bearings). Handy to know if you ever have to service the tranny. Would have been a hassle for me if I did not have a friend with a tranny shop.
I should also point out that with the conversion mentioned above in my previous response, I used the transfer that came with the 5sp.
Cheers!
not trying to pick holes in your wisdom....but....;p
my 85 bj60 didn't have a vacc shifter, so there may be a cutoff date within 1985 to be aware of for that...
the hollow tube shifter is actually quite nice to have, mainly for aesthetics, as it kinda looks all modern like...tho I guess in theory the purpose is to eliminate some vibration from your hand, and they're just as easy as a solid shifter to bend...you just have to bend it below the joint, and all is good.
but getting a 3b with the 5 speed behind it may not be a bad plan, from what I remember of my poor old B diesel, the 5th gear wouldn't have done me much good except downhill....:p
