For Sale 1984 Diesel
....."the body has the typical rust spots that many of these Landcruisers have, although none of it is too difficult to take care of." ........
I find the above statement to somewhat amusing. :)
Rust is easy. If there is surface rust use a spray can. No prep necessary. If there is bubbling hit it back down with a hammer and using some sort of filler to smooth it after you put a bunch of dents in you body panels. I suggest drywall mud as its cheap and drys fast. Hit it with some spray paint afterwards. If you have rust holes then you have to work a little more. Use some spray expanding foam and fill the hole. When the foam has stopped expanding and hardens trim the excess with an exact-o knife and apply a sticker over top. If you desire more flash cover any imperfection with aluminum checker plate.
See, if you know what you're doing body work is a synch!
I thought it was funny....though on second thought it's awfully close to my personal motto of 'beat to fit, and paint to match.':hillbilly:
