I am rebuilding the front axle and when I finished doing the pre-load procedure per publication 36262E my pre-load is around 20-22 Ft. lbs.
My questions is two-fold, the details of which I will explain:
1) Is my pre-load OK (seems heavy) ?
2) Why are there seemingly two different specs in two different FSM's, one of which my measurement would meet spec and the other it would not ?
Let me explain:
"Manual 1" = Toyota publication 36044E = Aug 1980 Land Cruiser = says it applies to FJ60 (and 40's, BJ's etc.)
"Manual 2" = Toyota publication 36262E = Production Dates 10/84 thru 1/90 = Does NOT specify it can be used with an FJ60.
"Manual 3" = Toyota publication #unknown (Front page not scanned on document I saw" = "1985 FJ60 Toyota Landcruiser Chassis & Body supplement" = Says to use manual 2 EXCEPT for the certain items contained in the supplement.
Regarding the front axle bearing pre-load:
Manual 1 =
tighten adjuster to 43 ft-lbs -> loosen adjusting nut -> retighten adjuster to 35-60 in-lbs -> measure preload at 6.2-12.6 ft-lbs -> tighten locker to 58-72 ft-lbs -> preload should still be at 6.2-12/6 ft-lbs
Based on what I did, I would be well out spec with this.
Manual 2 = tighten adjuster to 43 ft-lbs -> turn wheel to and fro -> tighten adjuster to 43 ft-lbs again -> loosen adjusting nut -> measure preload and define this value as the "frictional force"
-> retighten adjuster to 35-60 in-lbs -> measure preload at "frictional force" + 0.9 - 7.3 lbs -> tighten locker to 58 ft-lbs -> preload should still be at "frictional force" + 0.9 - 7.3 lbs
Based on what I did, I would be in spec as my "frictional force" was around 15ft-lbs which gives a final max acceptable range of 15.7 -22.3 lbs. Also note the typo of 0.9-7.3 pounds and NOT ft-lbs.. I am assuming they meant ft-lbs.
Manual 3 = says to refer to manual 2 for this part (the front axle is unmentioned except for alignment specs.
Confusing ?
I will post pictures.
Let me explain:
Manual 1 =
Confusing ?
