1982 2F Head Swap
yes it will work on a 75 but you would also need to change to flat top pistons.
.......Because the older domed pistons would collide with the underside of the later head which has a different combustion chamber that uses flat-top pistons. Frequently the problem is the reverse: when folks try to use the easier to find replacement flat-top pistons in the earlier engine and keep the domed head, lowering their compression ratio.
As mentioned above, since you have the later head, find a set of flat-top pistons to go with it.
Oh, whichever head you use, get it magnafluxed to make sure it's not cracked.
HTH
