- Joined
- Mar 24, 2006
- Threads
- 32
- Messages
- 378
Ok i did search FAQ on this one but i still want to run it up the flag pole to get the MUD consensus.
My clutch went out on my last wheeling trip. I had no prior issues with the clutch before that day. The last time i pushed in the clutch pedal to get into 1st gear i lost almost all hydraulic pressure. The next time pushed the pedal all pressure was gone.
When i checked, the fluid in the clutch master cylinder was almost completely gone. Yesterday i filled it again with DOT 3 and pumped the pedal to see if i could find the leak and it lost fluid and held no pressure, but i didn't see anything dripping out anywhere. (i will say that it was hard to see if anything ws leaking out because the bottom of the cruiser was still covered in wet mud) so it is POSSIBLE that it was leaking out soewhere but i just couldnt see it.
Any ideas on how to locate the leak? from FAQ searching it looks most likely like the slave cylinder? Any opinions?
Thanks in advance for the help
