1980 Stock Dizzy-improvements?
Philadelphia, PA
I have researched this on the site and am confused. I have a 1980 FJ-40 with 2F, stock everything. Can the performance be improved by adding an electronic ignition like Pertronix? I seem to have read some of Jim Chenoworth's articles that say after 1978 the ignitions are electronic?
As you see I am confused on this, if anyone can set me straight I would appreciate it.
I believe the '79> came from the factory with a fully electronic distributor.
So....you already have it. The "Big Cap"
Ed:)
ALready electronic. Not much to gain. Petronix replaces the points which you do not have ;)
If you're running a large-cap stock 1980 dizzy and you're looking to improve performance, stop looking at the dizzy; the problem is the stock carb. Just pull the air cleaner off and you will see something very different to what 78 and older cruiser owners see, and what 81 and newer owners see.
The primary bore on the 79-80 is actually BIGGER than the secondary, which is not normal. I consider this to be Toyota's tacit acknowledgement that the smog equipment SUCKED SOOOOO BAD by this point that they knew there was virtually no chance you'd ever get the secondaries to open, so they gave you a bigger primary [as well as taller gears in the diffs] to make up for it.
If you're de-smogging, there are things that I can do to improve that carb.;) Then again, if you're desmogged you could just consider getting a slightly older carb that has the venturis set up the traditional way.
Mark,
(I don't mean to hijack the thread, but I think this is an appropriate question at this point...)
I have a '79 that is de-smogged and has a Weber carb. I have been thinking of finding a stock carb to put back on, both because I wanted it back stock and because I have heard that they have some advantages. I was looking for a '79 carb to make it "right" but you recommend I put a <78 on it instead? Will this affect the value of the truck if I decide to do a "real" restoration? Would I be better of with a Weber or the stok pre-79?
Thanks!
