1980 fj40
pennsylvania
Im just about ready to put this truck on the road after taking 14 years to finish the restoration and have several issues. Fuel and temperature gauges do not work. Also 2 of the bulbs in the cluster do not light, (bulbs are good). Not sure if this is related to gauges not working. All major grounds have been checked. What is the best way to check that the gauges are working properly? I figured that I would solve this 1st before posting my other issues. Thanks
Get a FSM if you don't already have one. It will have a schematic in the back and will also include how to test the gauges.
And post pix of your rig-- on this site, nothing exists unless we see pix
Land Cruiser Porn.....
What about, pull the cluster. Figure out which wire provides +12v to the gauge lights. On my 76 I think it was a red/white stripe coming from the dimmer switch/headlight switch. I recall it being in the big round plug, right next to the WB ground. Turn lights on, fully turn dimmer to high, test RW wire. If it is hot and that WB ground wire is good then it has to be in the gauge. Or the connection to the gauge. If RW has no juice then test, clean the headlight switch.
On mine I had to adjust the copper prongs on the bulb sockets so they made good contact with the circuit board.
I will be watching with interest as I have an issue with a fuel gauge that shows half when full and about a quarter when empty. Have checked everything I can think of, and replaced the fuel sender unit, all to no avail.
Download this FSM: -► 98154 chassis-body '75-'80.pdf
and follow the test procedures for the TEMP and FUEL gauges. Note that the FUEL gauge has a built in Voltage regulator that feeds itself and the TEMP circuit. Make sure (blown fuse?) that you have voltage to the FUEL gauge.
Use a test light like this one
Also a big help: Clusters, Gauges, Speedo & Odo meters
Rudi
