For Sale 1980 FJ-40 Factory AC/PS!
Virginia Beach, VA
Hi Folks, I am posting this for a friend I know very little about this rig, but I am available to inspect it if anyone wants me to. I'll put the seller's contact info at the bottom.
The Good:
1980
2f
4 spd
Factory AC
Factory PS
Ambulance doors
Originally from North Carolina
New Suspension
New Tub (not installed)
Sand blasted body and frame
Frame coated with POR-15
A metric crap-ton of extra/new parts.(listed on the next post)
Over 20k put into it so far.
The bad:
A bit of rust on the body, frame looks good, but I didn't look real close.
The Ugly:
The truck is in mid restoration and the owner has run out of steam. Drivetrain is removed, interior is removed, (pretty much everything was taken off for the sand blasting.) I don't know the mileage. First pics will show before resto, and last pics will show current condition.
Price: 10k/OBO
Owner: Steve
Phone# 703-899-1689
ITEM CONDITION PURCHASED FROM
1980 FJ40 Landcruiser w/Factory A/C & P/S Clear Title Used Liberty Motors in NC
Haynes manual New Borders
Sandblasting (Frame & 95% of Body Parts)
Por 15 for Frame New
2 Steel Front Fenders w/SST bolts New Cool Cruisers of Texas
2 Steel Running Boards New Cool Cruisers of Texas
OEM Steel Front Bumper New Cool Cruisers of Texas
5 Piece Tie Rod Kit New Cool Cruisers of Texas
4 Red Shock Boots New Cool Cruisers of Texas
Bump Stop Kit (4) New Cool Cruisers of Texas
24 Poly Bushings New Cool Cruisers of Texas
Console w/Stereo Den New Cool Cruisers of Texas
Console Cup Holder New Cool Cruisers of Texas
Spring (HFS) Hanger Pins Greasable New Cool Cruisers of Texas
Shackles (HFS) Greasable bolt New Cool Cruisers of Texas
Wiring kit (Painless) New Cool Cruisers of Texas
Braided Wrap 1/4" Dia 20' New Cool Cruisers of Texas
Braided Wrap 1/2" Dia 10' New Cool Cruisers of Texas
Braided Wrap 3/4" Dia 6' New Cool Cruisers of Texas
Braided Wrap 2" Dia 4' New Cool Cruisers of Texas
Oil Sending Unit New Cool Cruisers of Texas
Water Temp Sending Unit New Cool Cruisers of Texas
Brake Kit w/SST Lug Nuts New Cool Cruisers of Texas
Parking Brake Shoe Kit New Cool Cruisers of Texas
Clutch Master Kit New Cool Cruisers of Texas
Radiator Hose Kit New Cool Cruisers of Texas
Front & Rear Seat Cover w/Wire Ties (Gray) New Cool Cruisers of Texas
Weather-stripping Both Front Doors w/3M Glue New Cool Cruisers of Texas
Weather-stripping Both Rear Ambulance Doors w/3M Glue New Cool
Cruisers of Texas
Windshield Cushion New Cool Cruisers of Texas
Wiper Motor Cover Gasket New Cool Cruisers of Texas
Washer Bottle Reservoir Kit New Cool Cruisers of Texas
Windshield Washer Nozzle New Cool Cruisers of Texas
Radio Antenna New Cool Cruisers of Texas
Battery Hold Down Kit New Cool Cruisers of Texas
Battery Tray New Cool Cruisers of Texas
Passenger Door Handle (Chrome) New Cool Cruisers of Texas
R&L Door Regulator Pulls w/Bezels New Cool Cruisers of Texas
Turn Signals Set of 4 w/Rock Shields New Cool Cruisers of Texas
2 Corner Reflectors New Cool Cruisers of Texas
R&L Light Markers New Cool Cruisers of Texas
Interior Dome Light New Cool Cruisers of Texas
2 License Plate Dome Light New Cool Cruisers of Texas
Paint For Trim Silver/Pewter New Cool Cruisers of Texas
Paint For Trim Gray New Cool Cruisers of Texas
2 Window Cranks w/Clips New Cool Cruisers of Texas
2 Mirror Door Gaskets New Cool Cruisers of Texas
Gas Cap New Cool Cruisers of Texas
Body Mount Kit (Red) New Cool Cruisers of Texas
Hinge Screw Kit Rear Ambulance Doors (SST) New Cool Cruisers of Texas
R&L Front Door Bolt Hinge Kit (SST) New Cool Cruisers of Texas
Windshield Hinge Screws (SST) New Cool Cruisers of Texas
Mirror Doors Screw Kit (SST) New Cool Cruisers of Texas
Wiper Motor Cover Screw Kit (SST) New Cool Cruisers of Texas
Bumperrette & Frame Bolt Kit (SST) New Cool Cruisers of Texas
Door Latch Regulator Screws Kit (SST) New Cool Cruisers of Texas
Tube Spare Tire Bolt Kit (SST) New Cool Cruisers of Texas
Grille Screw Kit (SST) New Cool Cruisers of Texas
Rear License Plate Screw Kit (SST) New Cool Cruisers of Texas
Front Bumper Bolt Kit (SST) New Cool Cruisers of Texas
Gear Shift Plate Screws & Nylock Nuts New Cool Cruisers of Texas
Windshield Glass Seal New Cool Cruisers of Texas
Seal, Rear Driver Door New Cool Cruisers of Texas
Seal, Rear Passenger Door New Cool Cruisers of Texas
Seal, Rear Corner Glass Rubber (Passenger Side) New Cool Cruisers of Texas
Seal, Rear Passenger Vent Window New Cool Cruisers of Texas
Seal, Side Bay Window (Passenger) New Cool Cruisers of Texas
Seal, Side Bay Window (Driver) New Cool Cruisers of Texas
Seal, Rear Driver Vent Window New Cool Cruisers of Texas
Seal, Rear Corner Glass Rubber (Driver Side) New Cool Cruisers of Texas
Weather-stripping Windshield Frame Top New Cool Cruisers of Texas
Gasket Body Tub to hard Top w(SST) Screws New Cool Cruisers of Texas
Hose Clamps (SST) New Cool Cruisers of Texas
Gas Filter New Cool Cruisers of Texas
Gas Tank Sending Unit New Cool Cruisers of Texas
Fuel Pump New Cool Cruisers of Texas
Front Axle Rebuild Kit New Cool Cruisers of Texas
Seal Rear Axel (2) New Cool Cruisers of Texas
Gear Shift Boot New Cool Cruisers of Texas
Shifter Plate Ring New Cool Cruisers of Texas
Transfer Shift Boot w/Ring New Cool Cruisers of Texas
Gear Shift Knob New Cool Cruisers of Texas
Transfer Case Shift Knob New Cool Cruisers of Texas
Rear Bumperrettes New Cool Cruisers of Texas
Rear Turn Signal Guards (2) New Cool Cruisers of Texas
Front Grille Emblem New Cool Cruisers of Texas
Hood Apron Emblems New Cool Cruisers of Texas
4-Wheel Drive Emblem W/Gasket New Cool Cruisers of Texas
FJ40 Emblem Passenger Side New Cool Cruisers of Texas
Brake & Clutch Pads (2) New Cool Cruisers of Texas
Gas Pedal Pad New Cool Cruisers of Texas
Front Floor Insulation Foil Back (Pre-Cut) New Cool Cruisers of Texas
Rear Cargo Insulation Foil Back New Cool Cruisers of Texas
R&L Front Door Seal Kit New Cool Cruisers of Texas
Dash Screw Knob to Windshield New Cool Cruisers of Texas
Hood Hook Windshield Kit (SST) New Cool Cruisers of Texas
Hood Windshield Rest Pads New Cool Cruisers of Texas
Gaskets Hood & Cowl Hinges New Cool Cruisers of Texas
Hood Hinge Screw Kit (SST) New Cool Cruisers of Texas
Hood Pad Kit (Rubber Cushions) New Cool Cruisers of Texas
Gasket Weather-stripping Kickout Vents New Cool Cruisers of Texas
Hood Hooks (SST) New Cool Cruisers of Texas
F&R Seat Belts (Set of Four) New Cool Cruisers of Texas
Windshield Visors (2) New Cool Cruisers of Texas
Rear Body Tub Assembly (New Steal) New Cruiser Parts
Front Bib (Steel) New Cruiser Parts
1980 Rear Ambulance Doors (R&L) w/hardware & Glass Used eBayer
Old Man Emu Steering Stabilizer New eBayer
Restoration Decals New eBayer
Heater service Kit New eBayer
Air Cleaner Assembly Used eBayer
Gas Tank Straps Used eBayer
Ironman 2" Suspension Lift Kit New eBayer
Frame Clips Restored eBayer
Front Floor Pan (Driver Side) New eBayer
Front Seat Panels Restored eBayer
Set of Four '82 & '83 Factory Style Wagon Wheels Restored eBayer
Air Inlet w/Hose Used eBayer
82-'83 Style Steering Wheel Used eBayer
Smog Air Pump Assembly Used eBayer
Roll Bar Pads (Complete) Used eBayer
Body Bolt Kit (SST) New eBayer
Gas Tank New eBayer
Pic of the new tub still in packaging
Your buddy would be better off selling the new stuff to put a dent in the $10g's he's aking, and sell the rig seperatley for $2000-$2500. Is the tub a repro or a clean OEM? If it's a clean OEM tub you could get 3-4k right there. Regardless, most guys on this site know FJ's and if they had 10g's to throw down on a project truck, it would be a hell of alot further along. Not saying you can't get close to 10 grand, but you may want to rethink how to.
Thanks for the tip. I said something similar, but he wants it all gone at once. Anyone who is interested should contact Steve directly. You never know what he will say until you ask.....
