1980 2F Engine and Drivetrain Benefits?
Nor Cal
Ok, I am trying to figure out all the benefits to having 1980's Engine, Running Gear/Drivetrain and 4 speed trans (I Know 4spd is good.) What about the others? Is it more durable and/or more horsepower? Thanks again everyone!!
Well someone please correct me if I am wrong here, but this is what I have found so far...2F was available from 73-84, 135HP, 210TQ, 4.2 Liter, 4 Speed. Also I guess the front axle came with Disk brakes as well....I am not sure what the internal gearing is versus stock 63 FJ45...Anything else please let me know. Thanks!!!
Front disc brakes are '80 to '84, unless someone has done a swap.
2F started in 1/75 and went to 8/87. There were many changes over the years. The four speed started earlier in the 74 model year. Changed tailshaft in 8/80 from sixteen spline to nineteen spline to mate to the split transfer case (improvement). With the 8/80 transmission and split transfer case came a different mounting system. Instead of the rear motor mounts on the bell housing it uses a crossmember under the transmission. In mid 85 the transmission got a spacer on the back to keep it the same lenght as the H55F. All rear axles imported to the US were 4.11s (a very few real early cruisers had higher gearing) until 79 when they went to 3.70s. Back to 4.11s with the FJ62 model.
Wow that is some great information!! Thanks for the input!! So one question/concern I have is that I have a FJ45 Shorty with newer 2F engine/drivetrain and the crossmember for the transmission wasn't there when I bought it and the bolts looks like they're pretty coated with dirt and there isn't anywhere on the frame to bolt a crossmember, is this something that is left off during the conversion process for this 45 application? Thanks again for any help!!
