1979 FJ40 Vancouver BC
Portland, OR
Time to sell my FJ40. This vehicle was registered in Alberta, and is currently NOT registered in BC so will require an inspection. I believe the tub will require major work or replacement prior to passing. Mechanically sound, and an awesome machine to wheel.
I can be reached at (778) 836.6255 for more detailed information and pictures. or email maljmclean@aol.com
Located in Vancouver, BC. $3000.00
FJ40 Features
- Bike Rack
- Tires 32x11.50 RI5Lt Bridgestone Dueler M/T [on chrome teardrop rims]
- Rear Spare LT 235 85R16
- April 1979
- Blueprinted Chevy 350 [early 70s]
-crank
-piston arm > balanced
-Flat-top pistons (10:1 Ratio)
-Ported/polished manifolds
-Valves ground @ 3 angles
-Ram shaft - torque @ low rpm
-excellent for crawling
- Bikini Top
Spare Parts [Barn]
- 2 Rear doors (bottom rust)
- 2 Front Fenders with signals (rust in middle)
- 4 Tires and rims (steel)
31’’x10.50 P15LPMn5 worm
- 1 rear tire holder
Known Issues
-Windshield Washer reservoir leaks/empty
-CD/radio not working
-Brake Fluid leak
-Driver’s side mirror cracked
-Dash is cracked
- Starter Issue when engine becomes hot
- needs a heat shield between starter and engine
