- Joined
- Oct 31, 2008
- Threads
- 2
- Messages
- 15
- Location
- United States
I am selling my Cruiser because it doesn't fit my needs anymore. OK, I want a new toy. We just moved from the seattle are to Mesa AZ. The rig has been very good to me for the last sixteen years The only time it has let me down is when I put something together wrong or when I was careless on the trail. It is a very comfortable ride and it does not fight you going down the road.. It will cruise 65 mph all day long, and the Flowmaster just sings to you. The tires still have a lot of life on them. I don't drive it much, so the tires only have about four thousand miles of wear and tear. The wheelin I did was was very mild. It basicaly brought me up to some great vistas and hauled my beer. I am sure I will have seller's remorse when it sells. Whomever gets it will love it for a very long time.(For past or current cruiser owners, you might hate it too.) Please try to get onto the 'Youtube' listing below . I tried to show everything on it, good and bad. I am sure I left out some information, so email me All Xtra parts will fit in the back of the Cruiser.
BODY
The paint job is original
Lucas 20/20 off road lights
Hardtop and rear doors have never been offroading. The hardtop gaskets (all five) are in excellent condition, and the original dome light works.
Grey denim Speciality Top soft top (with removable side windows, rear window, and split doors)
Full roll cage . The cage has four spreader bars and a plate that is welded between the two middle ones. on the plate is one clear light , one red light with hi/low setings. CB coax runs up to the center , one 12volt acssesory plug and for toggle switches. One for the ARB air pump, one for the engine fan , one for the front off road lights , and one for controlling a winch.
Extra set of driver and passenger (rust free) front doors . They are not color matched. The door pannels have cutouts for spekers. They have no door latch hardwear. That will have to come out of the existing doors.
Drivers and passenger front fenders from cool cruiser that are unpainted
A set of rhino-coated running boards from a 1979 landcruiser.
A pair of older tailgate doors (I was going to make a tailgate)
One tailgate insert from spector off road
ENGINE
Original 2F Inline 6 cyl.
GM alternator (two wire with diod)
Flex lite black magic Elec. Fan
Optima red top battery
FJ-80 brake master cylinder
Rebuilt Jim Chenwith Asin Carb Downey Headers(six into one)
2 1/4 inch tail pipe to rear Series 70 FlowMaster muffler
HEI/DUI distributor
Live wire sparkplug wires
Saginaw Power Steering pump with BTB mounting bracket
Extra stock starter (new)
Rebuilt Weber 32/36 automatic choke carborator with mounting plates and air filter
One original windshield washer jug with working pump and bracket
One nonemission thermostate housing
One (pressure tested) oil cooler
CHASS
Spring over axel lift with stock cruiser springs (not lifted springs.) The overall lift is about eight inches. In the middle of the frame there is two feet of clearence.
Front axle has been cut and rotated
Shackle reversal on front axel
Old man emu shackles and greasable shackle pins (not in the rear shackles)
Rock Buggy supply, HI steer
Chevy one ton tie rod ends
The tie rods are 1 1/4 inch diameter with about 3/16 inch wall thickness
Saginaw 4 turn/4 bolt power steering box
4 wheel disc brake. front are stock and the rear are chevy calipers and rotors. the rear brake caliper are by TSM and have a summit rear brake adjuster
The tires are 36"X12.5" TSL Radial SuperSwamper(on truck now, with a full size spare-total of 5) Depth on new is approx 5/8inch and tires on truck are approx 9/16 inch.
Tom Woods Extended front drive line with a C/V joint on the transfercase end
4.88 to 1 Gears (Yukon)
Warn Hubs
Bobby Long outer axels
Inner axels have been Martacked
ARB air lockers, front and rear
Stock H42 and 4speed and transfer case.
The front bumper will fit a Warn 8274 , 8274-50 winch
I do have videos on 'Youtube'. I tried to make a link for each one but it kept on telling me no. All you have to do is highlight , copy and paste one title at a time. Past the title on to the search bar and press search. You can also pull down my other videos under landcruiser4sale
TITTLES
1979 toyota landcruiser FJ-40 ebay forsale Mesa AZ wlk around
1979 toyota landcruiser FJ-40 ebay forsale Mesa AZ air lockers in
1979 toyota landcruiser FJ-40 ebay forsale Mesa AZ items included with sale of cruiser
1979 toyota landcruiser FJ-40 ebay forsale Mesa AZ damage
1979 toyota landcruiser FJ-40 ebay forsale Mesa AZ engine walk around
1979 toyota landcruiser FJ-40 ebay forsale Mesa AZ-65MPH
1979 toyota landcruiser FJ-40 ebay forsale Mesa AZ all lights work
1979 toyota landcruiser FJ-40 ebay forsale Mesa AZ cold start
1979 toyota landcruiser FJ-40 ebay forsale Mesa AZ undercarage
SELLING PRICE $11.000
BODY
ENGINE
HEI/DUI distributor
CHASS
Warn Hubs
TITTLES
