I am fighting the good fight and trying to smog my '79 here in California. I passed 2 years ago but failed a few weeks ago and the technician thought I was running rich so I removed the carb and found a local carburetor shop to bench test and check the jet sizes.
I recently removed my carb to send it to a local shop for inspection when they determined the primary and secondary jets were swapped so they swapped the jets and sent me on my way.
With the carb re-installed I test drove the truck and found that under normal acceleration there was lots of hesitation and stumbling and when it caught up there was lack of power. It seems as though there was a vacuum leak or line swapped or vacuum advance not working. I checked the distributor and found the advance to be working properly. I started tracing the vacuum lines to carb and found there was the VTV for the CB was going the wrong direction. Once I corrected the direction of the VTV the idle shot up fast and looking at the top of the carb with the engine running the secondaries are spewing fuel at idle.
My question is related to the FSM diagram, what is the circle with smaller circles and numbers supposed to represent:
Second question: for the advancer port in the diagram is that on the lower side of the carb next to the idle speed mixture adjustment screw and what is the rectangle the diagram has them going into?
I am having a hard time trying to understand what is in front of me and what is in the manual so any help is appreciated, I do great with pictures.
