For Sale 1978 FJ40 Land Cruiser
Memphis
Year
1978
  1. 40 Series
Mileage
94000
Color
Yellow
1978 Toyota FJ40 Land Cruiser in very good condition and garage kept for the last 5 years (since ownership). Very reliable daily driver, 4 speed manual transmission with original 6-cylinder engine. Recent major overhaul on most of engine compartment. IMPROVEMENTS as of 9/1/22. Replaced NEW every seal, gasket, and hose in the engine, transmission and transfer case compartments (fluid serviced). NEW ceramic coated engine head with precision resurfacing to match. Full cylinder re-build with valve adjustments. Timing is spot on. NEW heater valve, elbow and associated hoses, along with NEW voltage regulator. NEW complete exhaust manifold system and pipes (chrome) front to rear (+gaskets). NEW master brake cylinder and brake hoses (with flush). NEW radiator with full complement of silicone hoses. NEW thermostat w/ valve cover (+gaskets), water pump, fan clutch. NEW crank pulley, harmonic balancer, motor and transmission mounts, rag joints/bolts, steering coupler, oil level sensors / sending unit, fuel line heat shield, e-brake drum, spark plug wire set, plugs, fuel breather line, vented fuel cap. Just an all-around great driving FJ40 with tons of engine upgrades already done. Truck is located in Memphis, TN and owner / private seller is willing to coordinate nationwide shipping to your location. $39,800 (901) 491-8334 or charleshoch711@gmail.com
