1978 FJ-40 for Sale
Carlsbad, Ca
I am sad to put my FJ up for sale but I have orders overseas.:frown: I have only had it about 3 years. The Previous owner sunk a lot of money into parts to make a really reliable rig. I haven't driven it much in the past 3 years. I worked on it more than drove it.
Below is my advertisment. I am located in Carlsbad, Ca
Email me at IFORDJC@hotmail.com . Asking $11,500.
Very clean California Cruiser with very little rust. Mechanically sound with almost everything replaced in the past 5 years.
Passes CA smog (several times since smog rerun)
Kept very stock with great running original six and 4 speed transmission
New 2.5 inch HFS CCOT lift springs with 2.5 inch lift shackles rear and 1.5 inch lift shackles front.
30.5X10.5 Yokohama MT tires
Warn 9000 winch(never used)
Header
4 wheel disc brakes(stops great with no brake wander)
Minuses:
The vehicle had some front left hood and fender damage many years back. I purchased new/used fender, hood apron, and apron. Fender, hood apron, and hood are primed. New hinges and hood hooks are primed
The stock electrical water gauge is not operative but a mechanical water temp gauge was installed and the extra oil pressure gauge is installed but not hooked up.
Only rust is bottom of right rear ambulance door, lower portion of back left window, tiny spot on body above rear bumper.
Since 2006 had the below completed professionally with receipts($14K)
Rebuilt 2F with about 15-20K miles(done by previous owner)
All smog rerun and functional
New ceramic Header, intake manifold, and exhaust
New rear tank installed (but original was removed for more internal room)
New clutch and reconditioned flywheel
New stabilization plate between tranny and transfer case
New 22 gal rear tank
New CCOT locking center console
New parking brake
New front brakes(pads, disc, calipers)
New rear disc brake conversion
New wheel bearings on all 4 wheels
New rear axle pinion seal replaced
Rebuilt steering box
New Fan clutch
New Thermostat housing and belt
New 4-core heavy duty radiator
New 1-wire 105 Amp alternator
New battery and battery holder
New Warn 9000 winch
Herculined inside
Rebuilt carb
Since Oct 2009
Replaced transmission, transfer case, and axle fluids, spark plugs, spark plug wires
New Toyota shift knob
New transfer case leather boot
Painted 5 wheels(they were chrome)
Repainted and reupholstered both front seats to look original
Replaced choke cable
CCOT rear half gate
Upgraded to CCOT bright dash lights
Added mechanical water temp gauge, oil pressure(not hooked up), voltage gauges
New Alpine iDA-X303 radio, Alpine digital amplifier, door speakers, and 6x9 speakers. A satellite antennae is installed but need a longer cable.
Stripped and Painted entire frame, rear bumper, and front bumper frame when springs were removed. Axles and tie rods were stripped and repainted also
Stripped and painted Jack and rods
Stripped and painted air cleaner, license plate holder, Carb smog heater, skid plate,
New CCOT HFS 2.5 leaf springs rear and front with new bushings
New U-bolts
New 2.5 inch CCOT shackles rear
New 1.5 inch CCOT shackles front
New Greasable shackle pins
Replaced front shock pins
New CCOT shocks
New CCOT steering stabilizer
Front end alignment completed
Extra parts
Toyota Manuals and Haynes Manual
Rear custom rack that mounts over rear seats
Damaged hood, left fender, fender apron
Original springs, u bolts, shocks, steering stabilizer
Numerous other new Toyota parts
