1978 Desmog help
FL
I started a desmog on my 78 this past Sunday. I ordered a kit from Jim C. however my 2F has a header on it so the EGR threaded plug is too large and the EGR blockoff plate is too large. Has anyone been down this road? Suggestions on best way to cap the pipe going to intake and plug the pipe coming off the header are welcome.
Problem solved. I found a cap for the intake portion. Used Jim C. Plate turned around. The hole pattern didn’t line up. So I drilled a new hole. Went back to look at the EGR and the flange coming off of it was fabricated to fit the header. This is the reason that the EGR block off plate didn’t fit As intended.
