1978 Blinker/Hazard Lights
Washington
I have a 1978 FJ40 whose hazards do not work, the blinkers will only work if I manually move the arm up and down or else the blinker light stays on consistently if I flick the switch arm (they don't blink). I have tried everything I can think of. Has anyone experienced this issue and successfully resolved it?
My right turn signal will blink when headlights are off, but will stay on when headlights are in (and turn signal engaged). I've been told to check the bulbs to ensure they are correct, I've not done it yet though. You should beat me to it.
Electrical contacts can get dirty, corroded in switches and lamps. Grounds may be intermittent. How deep you want to go into this is your call. Cleaning the column-mounted turn signal switch and re-lubing can help.
