1977 Fuel Tank
North of Tulsa
Did the factory use any type of insulator between the tank and the floor board?
My tank is really nice on the inside but has (3) pin holes (so far) from rust on the outside. Lots of other rust pock-marks are close to being a pin hole. Floor board has almost the identical pattern of rust holes (can't call those pin holes....too large)
I can't swear that it was factory, but I just removed my gas tank this weekend and there were 3 thin 'pads' of ~8"x5" between the tank and the floor. Couldn't tell what material that was. It was firm but flexible with some effort.
As recommended on another thread, below is what I used. Available at any big box store. I just cut 6 or 8 strips and put them around the pan to stop any metal to metal contact. I put a few strips on top as well.
Another thread on this: Under Fuel Tank?
good luck...
edit: while I’m spending your money, @ToyotaMatt has got a plug for the bottom of the pan if yours is gone. I need to pick one up, too. (Plus I have some key work for him)
