For Sale 1977 FJ40 with Transplant
Iowa
Website
www.myfj40.com
Selling this for a customer. The engine, wiring harness and instrument cluster are from an 82 FJ40. The 57790 on the odometer does not reflect the actual miles on the truck but may apply to the 82 engine. (I'm checking) The truck itself reportedly has 77,000 miles and from the looks of that front OEM mat, I would not be surprised if that is accurate. Evidently the engine failed and she was in storage for several years. I have the previous two owners contact info.
The Engine is said to run great. Tested compression and ranged between 138-142. Transmission, transfer case and 4WD work well. New clutch, master cylinder. The Warn winch works. Family roll cage installed. Rock sliders below running boards.
According to the owner, it looks like it was repainted about 15 years ago. Very solid body. Newer lower door skins and rear sill. Otherwise all original metal. No oil leaks of any significance. Email or Call 515 864 1275 for more info.
Located in Hayward, WI
Offered at $18,500
Many more photos here - 77 FJ40 BLU
