- Joined
- Nov 5, 2010
- Threads
- 33
- Messages
- 713
- Location
- Southern Iowa
- Website
- www.springtailsolutions.com
- Year
- 1977
- Vehicle Model
- 40 Series
- Mileage
- 2000
- Color
- Green
Original Donor was a 1977 FJ40 with roughly 100,00 miles, typical extensive rust but with a solid frame
Body/Suspension:
Frame off Restoration; Frame sand blasted and then double powder coated
Vehicle was professionally painted in a non-OEM color of “Fern Green”
Every nut and bolt is either stainless, new yellow zinc or original bolts recoated in Yellow zinc
New PACOL Tub/Firewall and front fenders built specifically for this project using old Toyota tooling in Columbia using modern steel (To assure corrosion resistance, the complete underneath of the new tub and fenders has been professionally Linexed)
Inside of the Fiberglass cap was Linexed in white for sound deadening and improved lighting.
99% of the rubber seals for the hard top, doors and glass are OEM factory (Painstaking research and hunting was required)
ARB 2.5 inch Lift
New Toyota OEM Wheels with 33 inch BF Goodrich Mud/Terrain
Drivetrain:
New Chevrolet 350 crate engine, Ram horn headers with custom exhaust: Estimated 250hp (roughly double that of the original powerplant and more than adequate) There have been many SBC transplants in FJ40s…straight forward and reliable.
Modern Holley Viper Fuel Injection with engine management monitor module
GM TH350 3 speed Automatic
Twin stick kit on stock transfer case
New Transfer Case (2024)
MAF 28 gallon “long range” Fuel tank
Front and rear ARB Air lockers
Interior:
Speedhut Gauges
CB Radio
Hidden compartment
Vintage Air
Corbeau Baja RS recliners with seat heaters and seat sliders on Custom Springtail adjustable seat mounts
Metal Tech 6 point Roll bar with custom padding, professionally welded by Kelderman manufacturing
New Adjustable EZ Electric power steering
9000 watt inverter
Hidden LED lighting inside the hardtop lights up the interior like a ball field
Discrete LED Bar lights to light up the outside like a ball field
Misc Goodies:
Under hood ARB compressor with Tank access in cargo area
Custom center console with removable “Ammo box”
Trail Defense Custom front bumper with Warn VR 10,000-S Winch
4Plus Products FJ40 Rear Bumper/hitch/Full Tire and Cooler Carrier
And probably more little details that I have forgotten to list
