For Sale 1977 - FJ40 - Raleigh, NC
Raleigh, NC
SOLD 1977 - FJ40 - Raleigh, NC SOLD
1977 - Land Cruiser - FJ40 SOLD
I bought the truck in February 2006 and have used it mainly to haul my fishing kayaks. Previous owner built the truck for wheeling but that was not my interest so I know very little about how the truck would preform under those conditions. I do know it has served my purposes very well and has been very dependable. Previous owner went through and rebuilt just about everything and put on numerous new parts. The truck had 58620 miles on the odometer when I bought it in February of 2006, right now it has 63900+/-, so I've put on approximately 5280 miles.
Below is the information he gave me when I purchased it. He did most all this work in 2001.
This Cruiser is freeborn red. The body of the truck and tub was completely during the rebuild. Some rust spot on body panels. There are some wheeling dings but, overall the body is in OK shape. The interior is in good shape, with the smooth gray bedliner and factory seats with gray seat covers. The truck runs great and is very solid to drive. It performs excellent off-road and is comfortable to drive on the road.
New tub from an Arizona truck was installed on the truck.
The frame was cleaned and painted.
The transmission, transfer case, and front and rear differentials were professionally rebuilt with new bearings and seals.
The front axle was completely rebuilt.
2F engine - Replaced with another Cruiser engine by the previous owner after the the original engine would not fully engaging the distributor (which drives the oil pump).
Replacement engine has been de-smogged and approximately 83k miles on it.
HEI Distributor non-US vacuum advance distributor.
Custom 2.5" exhaust.
Pertronix electronic ignition and new starter
New clutch, pressure plate, throw-out bearing, pilot bearing, and resurfaced flywheel.
SM465 transmission: rebuilt w/ new brgs and synchros, plate style adapter (3/4" thick plate adapting to Toyota t-case).
Completely rebuilt 3spd transfer case (came behind FJ40s with a 3spd transmission: this has a lower low range than the original 4spd case).
ARB air lockers front and rear with new bearings (4.11 gears).
ARB air compressor with wiring harness.
Factory 4.11 ring and pinion gears.
All new bearings and seals in the front and rear differentials and axles.
Front Warn Birfield Eliminator Kit: replaces the birfield joints with custom axle.
Shafts and Dana 44 U-joints, also replaces hubs and lockouts with Dana 60 (1 ton) components.
Front disk brakes with stock pads and calipers.
33x12.50x15 BFG Mud Terrains w/ 80% tread on white steel 15x8 wheels.
2.5" Skyjacker softride suspension system with shocks.
1.5" over stock length shackles (heavy duty with reinforced cross-bar).
Power steering using Astro van PS box (mounts inside the frame rail out of the way).
GM style "teardrop" Power Steering Pump on custom bracket.
'72 replacement tub (including the firewall).
Gray bedliner on the interior of the tub.
Custom rock sliders with reinforced rocker panels.
Drop-down aluminum tailgate with internal storage area.
Gray seat covers over factory seats.
Full 8-pt family rollcage-fully custom.
Stereo/cassette and CB radio.
Good hardtop.
Full-length bikini top.
Custom rock sliders.
Drop-down aluminum rear tailgate with internal storage compartment.
