1977 FJ40 blinkers problem
Fredericksburg ,TEXAS
My left fender turn signal lights up and blinks fine. My right turn signal light comes on but will not blink. They are brand new turn signals from CCOT.
What's the problem? Ground, wired wrong, bulb or something else?
Sounds like ground. Try running a hot wire direct from batery and see if it lights. If it doesn't than its a ground or a bulb.
jaybonecrow said:
My right turn signal light comes on but will not blink. T?
This means that the right side turn signal circuit isn't sinking enough crrent to trip the flasher. The possibilities iclude:
1) Burned out bulb.
2) Incorrect bulb (low wattage)
3) Bad/corroded connection anywhere from the switch to the ground.
Not fixed yet!
Drivers side works fine. The passanger side amber light will light up when I turn my blinker on but it will not flash off and on. It just stays on. I ran a ground wire to the body but that didn't help. Could the rear tail light be part of the problem?
Sure. It is the whole circuit that counts, both front and rear. The left and right sides are separate circuits. Since the driver's side works fine, you know that the switch is geting power and that the flasher works.
I'm guessing it's the bulb. The ones that come from CCOT don't run enough wattage to trip the flasher. Had the same problem when I replaced the driver's side light after a smashed lens. Go to the autoparts store, buy a new bulb, and it should work fine. I tried everything first, (ground, wires, etc.) and it was the $@#! bulb.
James
