1977 (CA) Distributor info needed...
Here. Now.
Hello, all:
I have a 1977 ( July, California, smogged) Fj55, with a "non-USA" distributor and Mel's (Pertronix) ignition. Things run great, except at altitude, loaded (the truck). It really dogs down at the slightest hill. Downshifting to 3rd usually helps, and I don't mind taking my time anyway... My original dist has a two-port vacuum advance, and I'm wondering if that second vacuum port is for additional high-altitude advance. Can anyone tell me? I'd like to put the original one back on, with electronic upgrade (Pertronix, Mels, whatever), especially if it will help in the hills (sierras, 7-9000+ feet). I also need to be smog-legal, though they missed the difference at last month's inspection. The primary advance diaphragm on my original dist is also faulty, according to the "suck-test". And they're no longer available new, I hear. Anyone know a good rebuilder, perhaps a perfomance re-curve...?
All suggestions welcome.
Thanks,
Nial
Sounds pretty normal for a 2F at 7-9,000 feet. The primary reason is lack of air and your options are limited unless you run a turbo or supercharger. Having a working vacuum advance might help, but you don't get much advance with a wide open throttle at low RPMs. If your "non-USA" distributor has the knob on the end of the vacuum canister, you can try bumping up the advance a bit, but don't expect miracles.
Thanks for the info, Pin_head. Not looking for miracles, it just seemed more doggy than usual, but it was REALLY loaded down (wife, kids, a weeks worth of camping gear, beer, water, gas etc...). I was also having fuel filter issues too... Mostly I was wondering if my 2-vacuum port dist. that's supposed to be on there might have helped a bit at altitude.
Nial
