craigslist 1976 fj40....$8500 obo
Depends on the day
1976 fj40....SOLD
SOLD SOLD SOLD
• Inline 6 cylinder factory 2f
• new DUI distributor and wires
• New mechanical fuel pump
• New Gear reduction starter
• Fuel tank was installed new 2 years ago, new rubber fuel lines, new fuel filters
• Webber carburetor (plus a completely rebuilt Aisin Carb by Mark A. with new air cleaner assembly and filter)
• Saginaw power steering
• 5 BFG AT 33x10.5x15 (BRAND NEW) on Eagle Alloy Wheels
• New shackles and bushings on the 4 inch Sky Jacker lift
• Best Top Bikini top and full hard top with the classic ambulance doors (Also have a bolt on rear gate for when the top is off and soft half doors)
• Front axle rebuild kit that I have not had the time to install yet (every gasket needed for front end rebuild)
• CD player with IPod hook up in glove box and remote (2 speakers under dash)
• I just finished repainting the truck in Rustoleum Spruce Green.
• All bolts for hard top, doors, windshield and grill were replaced with new bolts during paint process.
• New HFS front bumper
• The interior tub was stripped down and I put Rust Bullet on before painting (I have pictures documenting this process)
• All lights and gauges work except for the driver's side rear marker light. (wind shield wipers, radio, high-low beam lights, fuel, cluster lights, etc. are working)
• The truck has a working front heater but no rear heater or AC (the rear heater hook ups are bypassed at the firewall in case a rear heater is reinstalled)
• Matching VIN numbers on the frame, engine, and body.
• Just had an oil change and inspection sticker
• New wheel cylinders on back right wheel, brakes checked and entire system flushed.
• The truck has redone upholstery on all the seats. (The rear jump seats are not installed as I have an ICON forward facing bench seat installed in the back. . .. It folds forward for cargo space and matches the grey color of the other seats.)
• Box of random parts and receipts (spare set of ambulance doors..one with no glass. . .lots of bolts and odds and ends.)
**This is a 1976 4WD truck. It has rust and it has dings. The rear sill is rotted through but it has been treated with Rust Bullet and a Cap put over it. The driver and passenger side of the body have rust underneath each door where the gutter drains tend to always rust on these trucks. The driver's side fender has a fist sized rust spot but has not rotted all the way through. Back passenger side foot of the roll cage has some rust underneath it. The driver's floor is rusted. Finally both quarters have some rust. They are covered with diamond plate. (All of this rust was found after I started going through the truck and I put Rust Bullet on it to stop the rust progression. My plan was to cut out and replace the bad spots as I had time and money) I just wanted full disclosure as these trucks can be misrepresented. It has NOT been restored....just fixed mechanically and preserved better. I think it's a perfect trail truck or with $1000 in new metal and a paint job she could be brand new.
**History: I bought the truck from Oklahoma and before that it was in Colorado. I have many receipts from previous owners as well as documentation on everything I have done.
I can help with delivery. Truck is located in Brandon Mississippi 39047.......
Interior
I've had some PMs about the interior.
I stripped it down and put Rust Bullet on it to take care of the surface rust. I Then put 2 coats of paint, original front floor mat, and rear cargo mat down, I have the ICON bench seat, reupholstered buckets up front and redone jump seats in storage. I have not put seat belts in the rear for the bench yet.
dash pad is excellent, I have visors but they are cracked pretty bad. Horn doesn't work but all other instrumentation is working, lights on dash and for controls work, radio/cd works well. Confer center console.
mornin bump.
thanks Chris!!!
ok...all PMs answered....pics sent to a few fellas.
thanks for the looks
Saturday morning pancakes.....bump
tuesday...im bored at work.....
bumpin
more pics
Sorry for the delay in pm response and with getting these up
inside cab, rust below passenger door, rear sill cap
more
current state of the head liner and interior
aannd more
driver side rust spot, cab interior and dash in great shape
sorry about all the pollen...im in central MS....aka pinetree country
more pics
and here is more of the head liner, rust spot on drivers side fendor and Saginaaw power steering
sorry for this..no star yet
and here is suspension and underneath....yes it has leaks but nothing that forms a drip or hits the floor (I keep cardboard underneath it)
as per the craigslist ad I have everything for that front knuckle rebuild
and last 3
here is the rust on the driver's floor board, driver's marker light I haven't wired up yet, and a shot of the new rear lights and you can see the new shackles and bushings and new BFG ATs:D
again....all the rust was cleaned down to bare metal and ample rust bullet was applied. I THEN painted over the rust bullet. I have not covered rust with spray paint and if you are interested please pm me for MORE pictures of the entire process from tub on frame to what is above.
Thanks for all the interest.
Man do I like this rig. A few quick questions...
- Is it a 3 or 4 speed?
- any shots of the engine bay?
Thanks Miko.....it's a 4 speed plus reverse. I have shots of engine bay somewhere....will post here when I get home to the computer.
They will show all new parts discussed in craigslist ad and current condition.
Thanks
as promised
driver's side:
upper radiator hose is about 2 years old
those are new fuel filters (up stream and down stream)
webber carb that runs well (once cranked..I think float might need adjusting)
and I have an aisin rebuilt by mark a with all the trimmings ready to be bolted on in a box....only thing missing is choke cable
brake system and rad were just flushed and good to go
you can see pancake in 2nd pic for saginaaw...it's great with 33s
passenger side
1 is new battery and battery tray, new DUI and wires
2 is new mechanical fuel pump and filters (just had oil change so oil filter is new as well)
3 is new GR starter from the 60 series
** new means within last 6 months**
like I have said lots of new parts
things I would still like to do in here, coolant line kind of runs into DUI and I havent properly rerouted it yet and there is some obvious loose ends and spaghetti syndrome going on (I guess that happens after however many "mechanics" and 35 years)
I am sure all the pics over the last 2 days will generate some questions/need for different pics....let me know
new door seals for all 4 doors, new front Toyota emblem and sun visors just discovered while cleaning garage!!
seriously....alot of new stuff will be on the ICON bench when she leaves
last bump to the top until Sunday....have a good weekend
