I'm having tail light/running light blinker issues in the rear of my pig. I was wondering if anyone has a wiring diagram?
I had a weird front left turn signal thing going on for a while, it turned out to be a bad ground. Ground jumper to the metal part of the light fixture bucket solved it. Just sayin. The side marker lights dont go thru the hazzard $witch, but you could have two different problems going... the turn sigs and stop lites go thru the haz $, but the f/r side markers and the f parking lites and tail lites and lic plate lites all come off the tail lite fuse thru the HEADLIGHT $witch.????? maybe the headlight switch, and a bad ground. You should be able to go thru ALL your lite sockets and pull out the bulbs. Then turn your switches on and measure for voltage from the metal ON the socket to the spring terminal IN socket. As you encounter sockets that dont show bat. voltage, then check from GOOD KNOWN SOURCE of ground to the spring terminal, have juice, then add a jumper to ground. If STILL no juice, then chase the wire(s) back and check for volts at each junction point till you find it or get to the $/fuse. Do you have lic. plate lites? Hope this isn't too unhelpful![]()
