1975 2F H2O Pump Pulley
Lafayette, Colorado
I'm trying to figure out which water pump pulley will fit on my 1975 2F rebuild project and I'm having trouble finding information on exactly which pulley to look for. The pulley off of my F motor won't fit the 2F water pump. I've already purchased a 6 blade plastic fan and will be buying a new OEM water pump. I won't have a smog pump but may install power steering down the road. Does anyone have a picture of the correct pulley for my application? Thanks.
Well, the pulley is a function of which waterpump you use. The pulleys are different between fan clutch and non-fanclutch. Sounds like you have a direct drive fan so get the pump for the direct drive/non-fanclutch and the pulley for same.
GL
Ed
Water Pump Pulley Pictures
Just wondering if anyone could post pictures of a 2F water pump pulley -- the one without the fan clutch.
I think it is the third one down....FP1801
Water Pumps
OEM Water Pump
From everything I've read here on MUD, most people say to go with an OEM water pump. People have had good luck with Aftrmkt as well but I'll probably go with the majority and go OEM.
I thought you wanted a PICTURE.....:rolleyes:
Picture: 2F water pump and two groove pulley for NO clutch fan. Mounted on 2/71 F engine. Uses the 6 blade plastic fan.
Thanks for providing the link to CCOT and pictures of the various water pumps. I do appreciate your help.
Thanks for the reference pic Coolerman. Based on your photo, I was able to pick up a used pulley on ebay.
