For Sale 1974 Toyota FJ40
Riding season is here and summer getting closer thank you think.
74' FJ40 that I invested countless hours and cash in the process of restoring this truck, the original 3.9L engine with 3 speed transmission run strong with no leaks whatsoever, great mechanical condition, frame is straight and solid, turns heads everywhere and looks so cool with the top off, typical rust for its age since in original condition so all it needs is a few hundreds in body work and this truck will be a real show queen.
During the restoration process, the following parts had been replaced:
Installed brand new clutch kit
SS brake lines (Front and Rear)
tie rod ends
New Battery + cables
valve cover gasket
oil pan gasket
bump stops (front and rear)
rear lights
engine belt
air/fuel filter
NGK spark plugs and wires
Engine & transmission mounts
brake drums and shoes all around
wheel cylinders (front and rear)
brake master cylinder
universal joints (2 front shaft + 2 rear shaft)
MSD ignition coil
New Tie rods and steering coupler
rear brake hard line
All fluids have been flushed and replaced
All hoses replaced.
I'm sure there is some information I left out.
the truck has the following accessories:
American Racing wheels Outlaw II wheels that's been painted black, Front and rear heater, Bull bar with PIAA off-road lights, Warn lock Tuffy lockable arm rest/center console with Jensen unit installed but not wired, Original rear jump seats.
The odometer reads +260,000 , and will go up slightly because of the daily use.
passenger side plate type spare tire carrier (not installed yet)
Asking $8000
Yes it is still available.
Some rust spots due to its age. I will send photos sometime this week. Happy holidays to every one.
Clutch has been replaced and it cost me a lot.
Been a while to update.
