1974 Pig
Northern California
Website
www.facebook.com
1974 FJ55
Over the last year I have been working on this 1974 FJ55 Wagon and it is near completion. I'm looking at down sizing my vehicle inventory and I'm only testing the waters here... If you are really interested, and I mean REALLY then send me an offer... We all know what it takes to get these old pigs to this point (A lot of $$ and a lot of TIME) so if you would like to finish this old girl off with a few of your personal touches and be on the trail this is your truck!
Performance:
NEW Empi Carb with Holley Fuel Pressure Regulator
Custom split header / Magna flow exhaust system
HEI Ignition
4 Speed Transmission with new Master cylinder and Slave cylinder
NEW Custom Aluminum Radiator
New Water Pump
New Hoses
New Fuel Pump
New Fuel lines and filter
New Optima Yellow Top Battery
Interior:
2005 Tahoe Power front Seats
Crow Racing rear seat belts
New Dash
New Glove Box
Floors have been stripped and sprayed with an undercoating
Exterior:
Body Stripped and Sprayed with an Epoxy Primer Surfacer
A few minor body mods performed to clean up lines
New Headlights
Suspension and Handling:
Spring over axle lift
Front Axle pinion angle set with turned steering knuckles for proper Caster angle
Rear axle pinion angle set to eliminate drive line vibration
New Pro-Comp ES3000 Shocks
Saginaw Power Steering
Rebuilt Steering Column
New Brakes
Steel Braided Brake lines
Rebuilt front axle
4X4 labs High Steer with 1 Ton Tie Rod ends
New Poly Bushings
33"X12.55X15 Toyo M/T Tires 85%
For a full write up on this pig check this link out:
https://forum.ih8mud.com/fj55-iron-pig-preservation-society/547167-74-fj55-build.html
Don't bother with low ball offers...
530-966-1300
When I call the # recording says your not taking calls at this time????????
Sorry about that... I had a billing issue with my cell provider.. I think we got everything straightened out and will be back in business tomorrow by noon...
