1974 HJ45 Restoration "Finally Finished"
Newnan, GA
Website
www.cwcruisers.com
This project started about a year ago. I cannot count all the questions I have asked board members. With everyones help the restoration is finally complete. A bio is under the first picture. Pictures are at the following site: http://www.fototime.com/inv/4414E22EB35EBE1 Thanks again for each person who gave me advice or a lead on a part needed. If you are ever near me in Georgia please stop by for a look and a personal Thank you. *** Also special thanks go to a particular board member "FJ Ben". He sold me the Truck and has been a great source of help and knowlege with the restoration. Thanks Ben!!
Wow! You must be pretty excited after going through the process of re-building the truck. I just finished looking through the many pictures that you linked.
Who did the various bits, like the media blasting and bodywork, etc? What would you do differently next time (if there is to be a next time)?
How come you didn't post up on a build thread as you went through the rebuild? I would have liked to have seen that anyhow.
I like a lot of things about the truck, however I was a bit nonplussed with what you did with the engine (before/after pics below). I can understand not wanting to crack it open if it was running decently, but why-oh-why did you paint EVERYTHING on the motor black like that, including the injector pump and lines?! I think the engine looked better before the paint was applied in copious quantities, but hey, one opinion is pretty much as good as another, and I hope you don't take the criticism badly.
You accomplished a lot and the truck looks great overall, plus you kept a cruiser on the road, so kudos for that. :clap:
Are you planning to keep the truck, or sell it? It looks like you have had quite a few different L/C's, looking at the table of contents on the linked page.
engine
Hello, Thank you for your kind comments about my restoration on the 45. Regarding the engine, when I purchased the truck the diesel engine had been rebuilt not that long ago. No running issues were found with it. Unfortunately when rebuilt they sprayed the entire engine moss green. Hoses clamps everything! Being a purist I wanted to dissasemble it and use correct colors etc... However, I could not warrant the extra time and cost when it ran perfectly. I opted for what I thought was the next best thing, a black engine.
The reason I did not post a bid up thread while doing the restoration is simple. There were times when I would get frustrated trying to find a part or with painting that I thought the project may never be finished. I have seen so many other projects get started and then sold in the middle just to be done with it. So I just decided to wait until the end. I do have a bio / list of what I used. I will include below.
Send: tdilad@gmail.com (his name is Gord) an email requesting a Diesel badge. He has a source but they are $$
** BODY CONDITION **
Although a farm truck for most of its life this vehicle escaped the dreaded rust problem most associated with Land Cruisers. The only body repair required was in the bed. A large tool box was installed in the front part of the bed, causing the floor under it to rust. The entire front section of the bed was replaced with a duplicate steel floor. It was repainted piece-by-piece using factory Nebula Green (color code #622) in base coat clear coat. **ALL STEEL** No fiberglass, aluminum, rhino liner, or diamond plate on this BEAUTY. Entire frame and all parts attached have been powder coated.
New parts include:
· Front fenders
· Windshield
· Door weather-stripping
· Window channel felts
· Wing window weather-stripping
· Hood bumpers
· Windshield hooks
· Hood hooks
· Front Bumper
· Radiator grill emblem
· Diesel grill emblem
· Front turn signal assemblies
· Rear turn signal assemblies
· Apron emblems
· Door mirror assemblies
· All screw, nuts, bolts, washers, replaced
** INTERIOR CONDITION **
Seats have new upholstery and frames have been powder coated. All dash controls, gauges, and lights in perfect working order. Australian version trucks did not come with a heater as original equipment. A heater from another 1974 Land Cruiser has been added.
New OEM parts include:
· Window regulators
· Door locks
· Dash knobs
· Transmission and transfer case boots
· Shifter knobs
· Dash knobs
· Brake and clutch pads
· Headliner
· Sun Visors
· Rear window weather-stripping
· Corner window weather-stripping
Powder Coated parts include:
· Heater
· Dash box cover
· Instrument cluster
· Hard top latches
· Door cover inserts
· Steering column
** MECHANICAL CONDITION **
This truck is powered by the original 6 cylinder “H series” diesel engine. The transmission is a 4-speed “H41 series”. Hi and Low range transfer case. Engine and transmission have been rebuilt. All engine, transmission, transfer case, differential, fluids and filters replaced. Axles, outside of brake drums, (anything that could not be powder coated) coated with POR 15.
New parts include:
· BF Goodrich All Terrain KO’S 31x10.50x15
· Old Man Emu Springs
· Old Man Emu Shocks
· Spring shackles
· Grease able shackle pins
· Major shim and gasket kit (front knuckle rebuild)
· Eight wheel cylinders
· Stainless steel brake lines
· Brake shoes and springs
· Parking brake shoes
· Glow plugs
· Radiator hoses
· Drive belts
· Tie rod ends
· Rag joint
· Hubcaps
· Frame
· Wheels
· Valve cover
· Battery holder
· Skid Plates
· Radiator screen
· Sway bar
· Spare tire carrier
· Bumper gussets
Vehicle ID # HJ4500148
maybe one day mine can look that nice
Thanks for sharing. Learn something new from every restoration posted here. I was wondering why my HJ didnt have a heater. I dont think the engine can get warm enough to even use a heater.
From what I gather is that your rig was probably shipped to a warm climate country. I have a troopy from panama that doesn't ahve a heater.
No electronics for it, no holes cut where the heater should go, etc
