I also wanted to provide some reference specs for our 40 Series leaf springs along with some tips to make the ride better. See below images of the TOY001B front leaf pack, and TOY002B rear leaf pack.
These are both Single Stage Leaf Springs with a 7 stack of individual springs. These leaf springs are looking for some added weight to be on them with the 7 stack. They are considered a medium load spring looking for to an additional load of 0-220lbs for the front and 0-440lbs for the rear. These will work with both the F Series and B Series engines, although the 2F and 3B engines are a bit heavier, that weight will help. The TOY001B and TOY002B are for the 1960-'80 40 Series. The TOY001B front leaf is also for the 45 Series and for the 1980-'84 42 Series. All other 40 Series in the longer wheel bases will use other part numbers front and rear.
If your 40 is bone stock, no added weight from any accessories, no front winch, just a stock Sunday cruiser, then I would highly recommend removing a leaf from the stacks front and rear for a better ride. Typically the #3 leaf is a good one to start with. Without any additional weight, they will be firm and sit a bit too tall, but again, simply remove a leaf to bring it back down a bit.
My recommended process is to get measurements before and after the suspension install. This data will help you dial in how the vehicle sits.
First, get your Land Cruiser on dead level ground on the current suspension setup and measure from the center of each hub straight up to the bottom edge of each fender. Do this for all 4 corners and record the data.
Second, do your suspension install as the components were sent, don't remove any leafs yet. Once installed, drive the vehicle around the block a bit, hit a bump or two, so everything settles in. Take note how it feels while driving, how it sits, how it reacts, how it handles, etc... Then get back on dead level ground and do the same measurements again. Record the data.
Now, compare the before and after measurements to see how much the vehicle changed, what the rake is (fore and aft), what the list is. You now have numbers you can use to make smart and specific suspension adjustments, like removing leafs. If you do end up removing a leaf go through the same measurement exercise again to see how much did it change, repeat and adjust as necessary.
I do this process every time I fart around with the suspension, and more importantly, every time I add or remove significant weight from the vehicle. This is best when adding/removing permanent accessories like bumpers, winches, etc... It's really smart to see how much the added or subtracted weight changes how the vehicle sits. Follow this process and the data will help you make better decisions for suspension adjustments resulting in a better ride, better weight support, and a better handling safer driving vehicle.
And if you have any other curveballs like an Aqualu alloy tub, Metaltech roll cage, aftermarket tube fenders, run it without the OEM roof, etc... or other mods that affect the axel weights then take that into consideration and rely on the measurement process to adjust suspension.
Again, typically if its a stock "Sunday Cruiser" then you will want to remove a leaf.
I love a good process! It's good to build the discipline to follow and refine a process.
I hope this novel helps!
Holler if you have any other questions!
-Miller
