For Sale 1974 FJ40 San Jose, CA
San Jose CA
Website
community.webshots.com
1974 FJ40 LandCruiser $9000 SOLD
Engine is 1978 2F rebuilt from Man-a-Fre, with cam and hi-compression pistons. About 1000 miles on engine. Turbo City EFI (GM TBI). DUI HEI distributor. New clutch/pressure plate/throw out and pilot bearings. Alum. radiator. Fluid heat riser. High Torque starter. All done at engine swap.
SM420 transmission (7.05:1 1st gear) AA adaptor to Xfer case. Marlin Crawler gears in Xfer case (3.64:1 low range). Disk parking brake. Front shaft large tube with 1350 joints. Net result 105:1 crawl ratio.
Front axle is 1979 (disk brakes) with ARB, factory 4:11 ratio. Upgraded Birfields. Rear has Detroit Locker.
Front springs Rancho, rear springs Skyjacker, all greasable pins, Rancho RS5000 shocks.
York compressor, lots of Kilby stuff, 2.5 gallon air tank.
80A alternator, dual Optimas (new 10/10), AGR PS box and pump, remote cooler and filter.
15X9 beadlock wheels from Stockton Wheel, 3.5" BS, 35" BFG Mud Terrains.
Warn 8274 Winch.
1974 Frame - no smog in Cali. Front spring Shackle swap. Front boxed for power steering, rear boxed at spring mounts. Round crossmember moved rearward. 1/4" skidplate.
1978 hood and windshield frame. Steel diamond plate corners. Kayline Top (also bikini top). Confer auxiliary tank set up as transfer tank. Confer console. Dashbox. Warn lights. Most pressure lines steel braided (ARB, Brake, PS). Roll cage tied to frame.
Built to wheel, not for show. I haven't wheeled it since 2004, so I'm selling it.
More pics to come.
Bump for a nice rig!
Some more pics
I've had requests for a few specific pictures, so I'll stick them here and the next post. The xfer case and disk brake are in the first pic, with some view of the underside sheet metal. Second pic is of the passenger floor board, third is of driver floor board. I just yanked up the mats and took the picture, so the leaves and dust add authenticity.
still more pics
first pic shows under the drivers seat. New paint since I took all the trail spare out and cleaned it, even has overspray on the hoses for the rear heater. Second pic is half the rear bed, rolled the liner off to the side to take the pic. Third pic is underside of bed, with right side showing the air tank.
Looks like a well thought out cruiser that's fairly priced. Good luck with the sale.
