1974 FJ40 in Central CA
Do you still have the steering wheel? I need the right horn button out of it please. shipping to 96913
also the light bulb that sits behind the fuel gauge if you still have it.
oh btw I don't plan on sending you any sort of payment for at least a year, so if you can get that stuff in the mail asap, that would be great.
I still have the complete steering wheel. This particular rig did not come with the independent right horn, left horn and rear horn buttons. They were all wired together. :D
I should have the light for the fuel gauge in the dash but the filiment is bad. You should be able to replace the filiment with no problems. I heard they are on the list of unobtanium parts but they are around.
I will strap the parts to a pigeon and give it your address. It is migration season so it should take less time to get it than normal mudshipping route so the payment time line should be good.
Is that why the pigeon hunting around the Visalia area is so good? They always have 40 parts attached to them!
Bump for flying parts!:D
Hey, Dan
do you have the brake hard lines for the frame?
I have some frame brae lines. I will have to check to se if they are for a FJ 40.
Thanks, I need later model stuff, as I've put '78 axles on the boy's rig
How 'bout the rear frame mount brake line and splitters. any luck?
The splitter is on the axle. I think I have the front one from the frame.
The brake line tab is the metal one with one bolt in the center holding two lines on?.
I need the front frame mount splitter and the actual hard line to the rear
Any luck on this?
Are you heading to Bakersfield?
Any luck on this?
# 71 on this picture or the one that goes between # 31 and #35 or the one at the end of #36?
From SOR's catalog I need:
086-35
36
44
76
I'm kind of piece-mealing here. '65 frame, '78 axles, '83 60 series master
