For Sale 1974 1974 Toyota Land Cruiser
Shingle springs
No smog required
Chevy 350
SM420 Transmission attached to stock FJ 3 speed Transfer case.
Almost new 35" Good Year MTR mud tires
Sprung over, shackle reversal,4 bolt steering box, above the leaf spring x-over steering
Front locker
Spray on bed liner inside from Line X
All hinges and brackets sand blasted and powder coated
Custom cage, powder coated.
Rear seat is removable
Full soft top and soft doors, almost brand new!
I do not have hard top or doors.
All work has been professionally done with no cut corners!
There are a few things lot wrong that I will list below. . .
1.The fuel gauge and blower for the heater work intermittently. Have not took it in to get it checked out but I have heard that they are on the same ground are positive circuit.
2.and there is some seepage of oil between the old gaskets on the transmission and transfer case. Not terrible.
3.The right front fender has a crack in the paint. Also the rear right corner marker light is cracked and there is a small dent on the right side of the marker lamp.
4. For some reason if you were to put the pedal to the metal the carburetor stars for fuel, but if you are pushing the pedal down at a consistent speed it runs fine. It just cannot be floored. May need to rebuild carburetor or cleaning out
I know FJ40 go for a lot of money in this condition and I have priced it completely fair to have all these things fixed in order to have a $25,000 vehicle! Now is your chance to own a Rockcrawler the only games value.my loss your gain
Please call or text with serious inquires
smoking deal at $15,000
Very nice!
Can you provide a little history of the work done, such as when it was painted, how many miles on the engine, was the engine rebuilt prior to installing, etc? Did you do the work to build this up or was it a PO?
Very nice looking rig!
Undercarriage pics, pls (trans, oil pan, knuckles, suspension).
What is the condition of the tub under the LineX ?
I have had the cruiser for over 6 years,
When I purchased I had a local shop replace the suspension leaf spring bushing, custom built cage, front axle rebuilt with locker,news gaskets between the trans and t-case The motor also received new heads at the same time. I do not know how old the motor is but it run goods and stays below 210 degrees Usally runs at 190.
As far as the tub it seems to be in good, it does have bondo on the front right fender. I have included the picture above.
