- Location
- United States
1973 FJ45 Australia Townsville $1500 ono SOLD
SOLD IN THE LOCAL PAPER FOR 1000 BUCKS
Hi guys,
Tried to sell it on eBay but had no luck so i thought i might try here.
Cheers
1973 FJ45 Landcruiser Ute
Unfinished project which has had the following completed:
The engine is a little difficult to start but it does run, definately needs a tune up.
The gearbox is a 4 speed, both axles are fitted with drum brakes.
The vehicle is partially complete but some parts will need to be sourced, it would also be suitable for wrecking.
Hi guys,
Cheers
- New Headlights
- New front indicator assemblies (not fitted)
- New tail light assemblies
- New hazard switch and flasher modules
- All new greasable shackles and bushes
- New rear swaybar bushes
- New rear shock absorbers
- All new tie rod/drag link ends (not fitted)
- New steering coupling (not fitted)
- All new brake shoes
- Overhauled wheel cylinders with stainless sleeves
- Bearings regreased new hub seals
- Rebuilt swivel housings
- New window regulators (not fitted)
- New spark plugs and ignition leads
- New water pump, thermostat and radiator hoses
- New seat belts
