For Sale 1973 FJ40
Battle Ground, WA
Regrettably we're selling our 1973 FJ40, it's gotten a lot of love over the years and been built up enough to be a real rock crawler if you want, or just a great functional trail rig. LOTS of upgrades, 1 ton running gear, includes an inventory of parts. We have a soft top on it now, and a hard top that needs paint, but has all the parts including two PERFECT doors that are already primed. We would prefer to sell it all together, but will consider just selling the truck and hard top separately.
PRICE: $18,500 (OBO)
ENGINE
* 4 Bolt Chevy 350 with Edelbrock Thunder AVS Carb
*Turbo 350 Automatic Transmission
* Np250 Transfer Case with Twin Stick kit
* Custom Dual Batter Setup with National Luna Intelligent relay system and monitor
* Harness upgraded to Painless wiring harness
* Brake lines are all ran in stainless steel
* All Fitting have been replaced with AN fitting and Braided Stainless lines
* Firewall mounted fuel pressure regulator and gauge for tuning.
* Built for toughness and durability and reliability
* New 4 core Aluminum race radiator and electric fan
* Shortly Header with black fiber glass wrap and locking header bolts
* MSD Distributor
* MSD Wires
* PLATINUM Peanut plugs
* Original (not reproductions) Mickey Thompson Valve covers
* Billet Spark plug wire looms
* Lokar billet Throttle and trans kick down cables
* Lokar billet Locking dip stick
SUSPENSION
* Suspension is sprung over axle on de-arched springs
* Rear end has a wish bone triangulated 3-link
* Front end has a complete custom shock hoops utilizing ID tube clamp for serviceability
* It also has a custom removable upper shock hoop stabilizer
* Integrated Radiator support with a uniquely engineered isolation system
* Full High Steer Cross Over Steering
* GM Saginaw Power Steering Conversion
* Front Disk Brakes
INTERIOR
* Custom Aluminum Dash finished in Wrinkle finished powder coat
* Custom Pelican Case glove box
* Tuffy Console
* Matching Autometer gauges
* Socal Cal Speed Shop custom gauge cluster
* All wiring harness using delpi-weather pack connectors
* Full Sport Cage with Seat Cradle (comes with Metal Tech Family Cage Kit to extend cage)
* 2 Full Suspension Beard Racing Seats
* 2 Crow platinum 4 point harnesses (Mounted Correctly)
* 26gal Man-A-Fre Long (Aussie) range gas tank
* Tub Full Linex'd inside
* Frame and Inside Fenders, Bib, under Side of Tub POR 15 after sanding and stripping No Rust!
* Custom matching machined dash knobs
* Custom frenched e-track cargo rails in rear bed for gear tie down
EXTERIOR
* All bolt replaced with stainless bolts/screw and hardware inside & out
* Custom Stainless grill
* Upgraded Headlights
* Hotchkis Billet Hood Pins
* Billet SOR hood hinges
* Custom frenched Defender 90 Tail Lights
* Bushwacker Flex Flairs (Rear)
* Soft Top
* Early Style 1/2 Doors with Soft Uppers
* Comes with custom bumper with Metal Tech Nose guard and Stinger
* 12,000lb Mile Maker winch with upgraded steel winch line
* 38.5 x 15 TSL Boggers on Black Steel Rims (comes with set of alum. rim as well)
* Comes with Metal Tech sliders (Not mounted to frame as of yet)
* Custom Exhaust by Punks in Vancouver
* Mohave high output heater
* Cb and Tuned antenna
* Foot man loops and front bib bezel power coated in Harley Davisdson wrinkle finish.
* Other various custom touches
FRONT AXLE
* Standard fj40 Axle housing
* 4.11 ratio
* bobby long cryo treated 'Super' birfield joints
* Asian manual locking hubs
* Reinforced Barbell style hangers
REAR AXLE
* Custom Length Danna 60
* 4.11 ratio
* Detroit mechanical locker
* Super beefy reinforced Barbell style hangers
PARTS
* Ready to paint late style doors (Complete)
* Ready to assemble hardtop with glass (needs to be painted and assembled)
* set of rear lower barn door (Needs to be painted to match)
* Metal tech kit to convert sport cage to full family cage
* Metal Tech sliders (1 set needs notched and welder 1 is ready to be welded to the frame both need powder coating)
* New stainless SOR windshield latches and hood latches (They are not installed)
* any other odds and ends / parts I can come up with.
https://www.dropbox.com/s/k8grmzy2tb53kgk/FJ40_01.jpg?dl=0
https://www.dropbox.com/s/w4j6bp9hubl2mct/FJ40_02.jpg?dl=0
https://www.dropbox.com/s/m13mxarob67u8bs/FJ40_03.jpg?dl=0
https://www.dropbox.com/s/5pd7hzsr7le60ki/FJ40_04.jpg?dl=0
https://www.dropbox.com/s/20fpgrde8oox4lk/FJ40_05.jpg?dl=0
https://www.dropbox.com/s/t12fdmjj87on51s/FJ40_06.jpg?dl=0
https://www.dropbox.com/s/rwf4sx0espldosu/FJ40_07.jpg?dl=0
https://www.dropbox.com/s/4f2nvcactu6uf9n/FJ40_08.jpg?dl=0
https://www.dropbox.com/s/i8d83muj61zgm5f/FJ40_09.jpg?dl=0
https://www.dropbox.com/s/j0a7gkpi7j3fjc7/FJ40_010.jpg?dl=0
https://www.dropbox.com/s/4dbbmnwff6alyoi/FJ40_011.jpg?dl=0
https://www.dropbox.com/s/kx6wqzgxey3go7x/FJ40_012.jpg?dl=0
https://www.dropbox.com/s/i9avmtui1kaw8m0/FJ40_013.jpg?dl=0
https://www.dropbox.com/s/g4uyhed2jpr5sfd/FJ40_014.jpg?dl=0
https://www.dropbox.com/s/t61170rlsrlphcs/FJ40_015.jpg?dl=0
https://www.dropbox.com/s/iozsd9m9ocro2ha/FJ40_016.jpg?dl=0
https://www.dropbox.com/s/238lrvey6a681c3/FJ40_017.jpg?dl=0
https://www.dropbox.com/s/cqhjvzirfmm5f5e/FJ40_018.jpg?dl=0
https://www.dropbox.com/s/4uthbaf3ht701tp/FJ40_019.jpg?dl=0
Here's a video so you can see and hear it running:
Dropbox is being slow to load, so I'll put a few of the photos in here:
