1973 FJ40 Starter question
Denver, CO
I'm really stumped on this. I can always find the answer by doing a few quick searches.
Starter went tango uniform. No big deal, got reman'd one to get it up and running. But if you look at the housing, the bolts are no where near lining up. The bolts are actually running in a different plane. With the typical starter, you have 2 bolt holes. This housing has 3 bolt holes. Not sure if I'm explaining it correctly. All original (as far as I know) so not sure what I'm missing. Thanks for any help!
Sounds to me like you have a Chevota V8 conversion using an aluminum bellhousing. If so, these use an older style Chevy truck starter that uses 3 bolts to mount the starter into the bellhousing, bolts running horizontally back into the bellhousing, not two bolts running vertically up into the engine block.
Thanks! that makes a lot more sense. Appreciate the help. Always enjoy the surprises on these things.
I
I can not make out your picture on my phone but if your saying the reman one uses three bolts to mount to the bell housing it's the wrong starter. Not sure it Toyota ever used one that had three bolts it wasn't for any F series engine 92.
Your “all stock” reference is inappropriate, and obviously what threw LITP off. The “three bolt” reference automatically took me down the Chebby hole, as obviously it did for @Downey .
It would be nice if you could be more precise when.....never mind.
