For Sale 1973 FJ40 Daily Driver $7000
I've decide I have to many projects to enjoy this thing the way it deserves. This is an awesome fj40
This thing is solid as a rock and runs strong! It's geared to run down the interstate at 60 mph or in low 4 you can crawl up and over anything. With the front axle moved forward 5 inches and 1 ton power steering, you have no drifting in the tire groves on the road. Very secure to take down the road. There are a few things on the list I haven't gotten to. It needs a new oil pan gasket and a new rear transfer case seal as they are leaking. Also the prior owner installed new motor mounts which lowered the motor a bit. This changed the angle on the rear output from the transfer case and the angle on the rear axle which caused a slight driveline wobble from 30 mph to 36 mph. This is a common problem and easy to fix by cutting off the rear axle spring perches and welding them back on with the correct angle. I need a new welder or else I would have done this already.
Clean title and collector plates (which saves on the sales tax)
I would rate the body 6 out of 10. It does have some minor rust but in far better shape than most I looked at when I bought it. My plan was to restore the body so I was looking for one in the best shape with the least rust when I purchased it.
1973 FJ40 Landcruiser
300HP Small block Chevy 350 CI from a 1973 Chevy ¾ ton truck
Edelbrock performer intake with Edelbrock Carburetor
Hydraulic roller rockers
High volume 8 quart oil pan
Duel 2.5 inch flowmaster exhaust
SM465 GM transmission from a 1973 Chevy ¾ ton truck
Deep Cycle battery
Aftermarket gas tank
Stock transfer case
Brand new drivelines
Toyota axles with wheel disk brakes
Warn manual hubs
Lockrite lockers front and back
Skyjacker life kit with Rancho shocks
Braided break lines
BFG KM1 35 X 12.5 with lots of tread left on new bead locker style wheels. (not bead lockers, just the look)
Greasable shackles and bolts
Power steering with all brand new 1 ton GM steering components
Front axle has been move forward 5 inches
Speedo, oil pressure, temp gauges, front and back heaters with fan, wipers, headlights all work perfectly.
Mastercraft bucket seats with 5 point harnesses
Bench seat with storage in the back
Bikini top and half soft doors
Full hardtop and doors condition wise it's a 7 out of 10
CD player with 2 8" subs (I was going to rewire so I have it pulled out but it worked before I pulled it)
I'm sure I'm forgetting stuff...
Asking $7000 OBO but for $7500 I'll through in a Warn 8274 winch (needs new $100 clutch pack)
Send me an email with your phone number and I'll call you back. I'm located just north of Seattle WA.
Thanks
Jeff
http://seattle.craigslist.org/see/cto/4054117594.html
Everyone chant with me.....Flip...That...Bezel....Flip...That...Bezel
