LC Family
- Year
- 1972
- Vehicle Model
- 40 Series
- Mileage
- 103000
- Color
- Gray
This 1972 (9/'71) Toyota Land Cruiser FJ40 is for sale by the owner of the last 25 years. You can go off-roading as soon as next weekend!
Asking Price: $16,500.00
Size: 2-Door Convertible. Color: Grey (Primer) exterior, White interior.
Mileage: 102,600 (Assumed).
Fuel & MPG: 14mpg-ish w/ Regular Mid-Grade (87/89).
Engine: OEM F Series OHV Inline 6 Cylinder 3.9 Liter.
Transfer Case: OEM with H2, H4, and L4.
Transmission: OEM 3-Speed Manual on the floor with 2nd and 3rd gear synchro.
Steering Box: Box and Column are not OEM but Chevy? (this was done before I owned it). I do have and am including an OEM Assembly if you wish to switch it back to the original set-up.
Exterior Features: 13” of Clearance, Warn Front Locking Wheel Hubs, Removable Doors, Removable Top, Rear Lift-Up Door Hatch, OEM Swing-Out Spare Tire Mount, Trailer Hitch, and five 31” BF Goodrich All-Terrain T/A 32X11.50 R 15 LT tires that still have the nubbies!
Interior Features: Fold-Down Front Seats, Fold-Down Rear Bench Seat, OEM Front and Rear Heaters (for Crawl Heat Dissipation), Brights on Floor, and Side Foot Vents.
Safety and Security Features: 4 Seatbelts, Roll Bar, Locking Storage Box, Locking Gas Cap, and Wheel Locks.
Care: In its 25-year life with me, I have done the following to this vehicle:
- Replaced brake master cylinder, all drum cylinders, and front brake hoses (8/’25).
- Replaced air filter (8/’25), battery (5/’22), and tuned engine for timing and idle (passes CO emissions and I have completed that for you already - CO paperwork is ready to be passed on to the new buyer).
- New OEM Wiper Blades (9/'25).
- Replaced rear hatch handle and gasket (9/'25).
- Low mileage on current 31” tires.
- Replaced exhaust system and fuel filter.
- Replaced voltage regulator, ignition coil, ignition wires, and spark plugs.
- Replaced front axle assembly to match rear 4:11:1 ratio.
- Had main radiator and rear heater coil overhauled/serviced and replaced most coolant hoses.
- Replaced speedometer cable and emergency/parking brake drum assembly.
- Had rear seat re-upholstered to match front seats.
- Added OEM rear seat seatbelts, rear bumpers, and spare tire mount.
Additional items to be included in the sale: Bikini Sun Top (BesTop), OEM Bottle Jack w/ Tools, many extra NEW parts (OEM Parking Brake Cable, Turn Signal Switch Assembly, Steering Box Column Boot, Steering Box Shaft Nut, Valve Cover Gasket Kit, Transfer Case Gasket Set, Transfer Case Shaft Seal, Speedi-Sleeve for Parking Brake Drum/Transfer Case, Unused Oil Seals & O-Rings, Fuel Tank Sender Gauge, Set of Fuses, Set of Exhaust Studs, and Can of Gray Duplicolor), and many extra used parts (OEM Steering Gear Box, Steering Column, Steering Column Bracket, Linkage Rod, Steering Box Column Shield, Fan Belt, Window Washer Fluid Reservoir with Washer Pump, 4X extra set of OEM Pinstriped Wheels with Michelin Radial LT235/75 R 15 XCH4 All-Season Tires, a variety of OEM Radiator Hoses and Clamps, Roof Seal, Set of Ignition Wires, Ignition Coil, Pair of OEM Windshield Wipers, and a variety of OEM nuts, bolts, washers, and screws).
Most parts are still readily available for this vehicle through places like Specter Off-Road, Cool Cruisers of Texas, and Cruiser Corps (among others). This has been a dependable vehicle and has treated me well. It has always done everything I have ever asked it to do. I bought it 25 years ago to eventually restore when it died – IT NEVER DIED. Looking to give it a good new home.
No Trades.
No Trades.
