1972 FJ40 W. Montana
Western, MT
For Sale :
updated 2f, 4spd transmission, 3spd transfer case
Header, Aisin carb
converted from cable pull accelerator to linkage type
New fuel line, fuel filter, and fuel return line
New rear main seal, new seals throughout transfer case
New clutch, pressure plate, throwout bearing, pilot bearing, machined flywheel
New slave cylinder
4” lift
Used Toyota bucket seats installed
New set of 5 33x9.5 tires and wheels
New driveshafts, and u joints
New E-brake rebuild kit, installed, needs to be adjusted
New E-brake cable
New Speedo cable- something still not right as speedo needle bounces
New shift knob for both tranny and transmission
Newer dash pads…top and both sides
New Toyota coil
New Crane Fireball electronic ignition conversion
New Toyota (non-US) distributor
New battery
New alternator
New voltage regulator…napa vr607
New bulbs in gauge cluster
Hard top and hard doors included… all glass…top needs some work
Bestop softop with doors…crack in back window
Tuffy console
various extra interior knobs and cables…throttle, choke, headlight…uninstalled as is
used rear marker lights…uninstalled, as is
parts for a saginaw power steering mod...all parts from Marks offroad...new in box...
also new reman steering box and pump...all you need is mounting bracket and pulley and hoses
This has been a good cruiser....I am selling to purchase another that is already built to my needs... I just do not have the time that I thought I did to get this one to that point...
A little rust... rear sill is decent, frame is good, floorboards good...do not know condition behind diamond plate
Original paint so it is not hiding anything
Mileage is unknown...
This is a real solid rig
Transaction needs to take place soon, or I will just keep this one...
Asking $6000
email: caddiscaster@hotmail.com
