For Sale 1972 FJ40 time to move on $3800
Dayton, TN
Runs well and drives ok. I suspect it was used as farm/hunting truck in a previous life. I used it for cruising around town and some dirt roads and trails. Might be a good project.
Clean Title
Located in Dayton TN.
1F Engine, runs strong
JTO Header
Rochester 1bbl "Pot-belly" carburetor
Mallory distributor w/ dual points
FJ60 gear reduction starter
3-Speed, only a few hundred miles on new throwout bearing
Aftermarket tachometer, oil pressure, voltage, water temp guages.
Interior rhino-lined years ago.
4-wheel drum brakes
manual steering
33x12.50 Interco TSL tires
Doesnt work:
horn
factory oil press, temp, ammeter guages
odometer
heater/fan
parking brake
I recommend you bring a trailer. Brakes starting to develop some issues. They work sometimes and other times require a pump or two to get much stopping power.
The body is rough as you can see in the pictures. I have sprayed rust-stop on all the body rust. No spare tire or spare tire holder. The worst spot is on the underside of the tub under the driver seat. The seat isn't going to fall through or anything, that's just the worst spot, but its also the worst spot to get a picture of.
Life moves on, I do not get to use it or enjoy it like I used to. Hopefully someone will keep the old lady going and not let her sit unused for months at a time.
$3800
Will be posted to Chattanooga craigslist tomorrow.
42three-88three-nine42three. If after 9pm, text only please.
Pm and text sent
