1972 Aisin Carb Float Issues
Pendleton Oregon
Website
www.oregongrain.com
I believe I have tracked down my frigging carb issue. I have a paddy wampus float. i.e. the float is sticking.
Same symptoms as my previous post a while back. Drive a while and the engine sputters and no power. Kill the engine and look at the float bowl glass and it is empty. Crank it a bit fill the bowl...drive a while longer. Repeat.
So I have replace all the lines, fuel filters, pump and have narrowed it down to the float.
Question: How do I keep the float from sticking?
Question: Does the rod the float attaches have the ability to slide back and forth? When I popped the top of the carb I checked the float. It seemed to move fine..but I notice the rod it was attached to could slide out quite easily if it wanted to.
Gasless in Seattle...
