- Joined
- Dec 14, 2014
- Threads
- 7
- Messages
- 20
I purchased my first LC about 4 months ago, 1971 FJ40, original everything, not the best condition.
I went to change my spark plugs, ignition wires, and distributor cap and rotor the other day and I noticed that the firing order is different from the firing order mentioned in my Haynes manual.
Haynes manual (and everything else I read) says: 1,5,3,6,2,4 (1 being the closest to the radiator)
I forget what the firing order currently is, I'll be able to check letter. I did notice that the current firing order is completely different from the correct order, it isn't just in reverse or something simple like that.
The engine has been running since I purchased it, perfectly fine for a 1971 as far as I can tell. I did end up changing the cap, wires, and plugs, but I simply put them back in the incorrect order, as they were. I needed the vehicle to run, so I couldn't mess with a system that I know works. The engine fired up. I would say it started with no problems, but the very bad cold where I'm at has caused the fj40 to struggle to start for the past month and a half.
I'm a little confused. I thought that changing the firing order (at least in most combinations) will prevent the engine from running smoothly, as in it would seriously mess stuff up. It doesn't feel like anything is messed up, as far as I can tell, it seems to run well.
I will post the current firing order as soon as possible. Please, any help is greatly appreciated. I'm sort of freaking out right now knowing that I'm running a vehicle with the improper order like this.
