1971 Harness
Lincoln, CA
I know there is a thread out there with a 1978 harness so I'm trying to duplicate... there are a ton of wires in this harness and I have a few wires I'm confused about.
Thanks to coolerman for getting me this far...
1. Horn
2. Passenger Headlight Bucket
3. Passenger Turn Signal
4. Passenger Marker Light
5. Horn Relay
6. Heater Fan
7. Rear harness
8. Rear harness
9. Courtesy Light (soft top model)
10. Starter
11. + Battery terminal
12. Starter Solenoid?
13. Accessory Outlet(for the little pocket light)
14. Longer wire = oil sensor
15. Shorter wire = temperature sensor
16. Cigarette Lighter
17. Courtesy Light switch
18. Hazard Switch
19. LR (Blue/Red) Rear Heater B+ Jumpers over to the rear heater switch to provide power
20. Front Heater Switch
21. Wiper Switch
22. AMP gauge
23. Gauge Cluster Harness
24. Gauge Cluster Harness
25. Fuse Block
26. 4wd Light
27. 5 amp hazard fuse
28. key switch connector AM = BR Start = BW, run = BY
29. Headlight switch
30. brake light to the left of the cluster and turn signal indicator light above it
31. Parking Brake Switch
32. Turn Signal Wiring
33. dome light
34. Wiper Harness
35. Emissions computer
36. Horn
37. Brake Switch
38. Flasher Relay?
39. Reverse Switch
40. Sinewave generator (connects to speedo cable)
41. Washer Motor
42. Voltage Regulator
43. Floor Dimmer Switch
44. Brake Pressure Sensors
45. VSV
46. Alternator
47. Horn
48. Driver Turn Signal
49. Driver Side Marker
50. Driver Headlight Bucket
19 LR(Blue/Red) is the rear heater B+. It jumpers over to the rear heater switch to provide power
27 5 amps this is the hazard light fuse
33 is indeed the dome light
36 is the horn
37 should be the brake switch
39 is the reverse switch
41 is the washer motor not 39
Hope that helps!
Believe your right about 28 being ignition switch wires. 30 I believe is for the brake light to the left of the cluster and turn signal indicator light above it. 26 guessing is 4WD light and turn indicator light above it. These are at the end of the circuits and all four lights grounded with the dash from what I remember. Curious of the month of production. Thought 71 had a single plug for the turn signal switch. I have a 71 (month unknown) FST harness somewhere but it is currently MIA.
My 2/71 has the individual connectors for the turn signals. I'm not sure when the switch over to the single plug occurred. 72-73?
Yes 28 is the key switch connector AM = BR Start = BW, run = BY
26 is indeed the 4WD light. A small sub harness plugs into that with the bulb socket on it that plud into the housing that screws into the dash
30 is the turn signal indicator lights for the dash bulbs. A sub harness plugs into this and has the bulb sockets on the end of it that plug into the holes in the dash.
73 had the on column turn signal switch. So many just 72 had the plug. I believe I've come across a couple with plugs in my stash but never had either a 71 or 72. Believe I must have stripped from junk yards many years ago.
26 and 30 both show two bullet connectors which should be for a lamp each connector right? I remember when the sub harness with the lamp holder popped out socket the light didn't work until I plugged it back in. Did this change and two wires each lamp later? If it did I would think a male/female bullet connector would be used so the wrong wire did get plugged in the ground side causing a fuse to blow.
This is the wiring diagram for a 1971 model. Cant remember where I got it from though.
That would not be a 71 for US market. The dimmer switch being part of the turn signal switch didn't happen the 73 model. Dual back up lights 74 model. Single license plate light ended early in the 74 model year.
Not to mention there are many wire color code errors in that schematic if comparing to my 71. No purple wires in my harness. ;)
Hey Ken appreciate the post of this schematic. Any idea where this schematic originated? I added it to my collection cause it had to represent some Cruiser somewhere!
It appears that the rear turn lights are over to the left side of the schematic and labeled left/right side turn signal light. This must be a third world country truck since it appears to have the separate brake/turn lights? Also again all the wire colors don't match anything I have ever seen.
Only market I remember having separate brake turn signal pre 74 model was Australia. Since Ken is in Australia that would make sense. In another thread Ken has going I posted a link to a 64 FJ40 FST that had the separate lights from the factory.
