So putting my FJ40 back together, wiring things up… Missing my reverse switch for on the column of 3 on the tree. That is if it was ever there. So the hunt, any ideas where to find a switch a bracket?
Last one listed was 2023, so none listedThe classifieds
what is the aftermarket one you bought, and i have the bracketDo you just need the switch or the bracket too? I found an aftermarket switch that worked for my needs
Where do you see in stock for a 71 FJ40 with column shift 3 speed?switch 182-13b $69 shows in stock
used back up switch bracket 182-134A-U $24
Yeah they only have for the 3 on the floor, not 3 on the column if you read the description. They do have the bracket thoughThe sor link I provided above. Box left center "back up switch assembly" has the parts click on the blue 13, and a window will open
Called and left a message, looks you have them…
I wrote about it here 1970 in CT - https://forum.ih8mud.com/threads/1970-in-ct.969552/page-6#post-139455121 I I
Just came in from the shop and found your message. I will call you tomorrow.Called and left a message, looks you have them…
